Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 05-14-2012, 03:01 PM   #1
mice coming through dryer vent
I am having a problem with mice coming through my outside dryer vent. Its the flap type. Is there any kind of screen cover I can buy to stop this invasion? And I have taken steps to kill them once they are inside. But I would just like to keep them out. Any help would be appreciated.
zellnorma is offline   Reply With Quote
Old 05-14-2012, 03:04 PM   #2
Any screen you put on there will collect lint and need regular cleaning. I am sure you could make something using the screen they sell for windows and it would be cheap.
mcfarton is offline   Reply With Quote
Old 05-14-2012, 03:15 PM   #3
Thanks. I have thought of that but not sure how to attach the screen to the vent for easy removal to clean.
Old 05-14-2012, 03:22 PM   #4
post some pics. If you buy a whole roll of window screen and can find a way to attach it with a zip tie. I wouldn't clean it I would cut it off and replace it. You can figure that 8 dollar roll and 4 dollars of zip ties would last about a decade. Just make sure you remember to clean/change it before you have a fire
Old 05-14-2012, 04:48 PM   #5
sounds like it's ground level. extend it like a periscope so the mice can't reach that high. that might work. that way no screens need to be used
bionictony is offline   Reply With Quote
Old 05-14-2012, 06:23 PM   #6
pest control operator
Getting in the outlet of the vent simply gets them into the vent hose-how are they getting out of the vent hose into the laundry room? The vinyl type of hose is easy to chew through-check it carefully. If necessary, replace it with the foil type hose.
Any screen mesh small enough to keep out mice will clog up too fast with lint. Find a new type of vent configuration.
Are you positive that this is the only way they are getting in to your house?
PAbugman is offline   Reply With Quote
Old 05-14-2012, 06:45 PM   #7
Never heard of that one.
If you would post a picture of what you have now someone could come up with some good ideas.
Condensation accumulating in dryer vent. luckie_reubs HVAC 23 05-19-2012 09:05 AM
Dryer vent installation Wiscbldr Building & Construction 3 05-04-2011 04:14 PM
Dryer Vent Leaks Water glennonr General Discussion 9 04-23-2010 08:50 AM
Dryer Vent Question jlaky2000 HVAC 2 03-13-2008 09:22 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
