Malathionn Smell - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 10-16-2012, 08:54 PM   #1
malathionn smell
What does malathion smell like after being sprayed on wood for termites?
Debbie Jones is offline   Reply With Quote
Old 10-16-2012, 10:28 PM   #2
Rewards Points: 13,300
I thought that stuff had been outlawed years ago.
It stinks to high heaven.
Why are you asking?
http://www.chem-tox.com/malathion/research/
There's a bunch of far safer chemicals that can be used.
Old 10-17-2012, 07:13 AM   #3
Too Short? Cut it Again!
Without "Scratch n Sniff" capabilities it would be hard to describe what malathion smells like. I can only describe it as having had a very "insectiside" chemical smell to it. If you are referring to a distant past application I doubt you are presently still smelling it.
Old 10-17-2012, 07:16 AM   #4
pest control operator
Malathion, while low in toxicity is high in odor due to itsí sulfur compounds. I never heard of it being used professionally for termites. I think itís still available for outdoor tree/shrub use like bagworms, japanese beettles, etc. but there are other insecticdes that are more user friendly for that. Itís an old chemical that probably isnít needed anymore.
PAbugman is offline   Reply With Quote
Old 10-17-2012, 05:55 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
When I was in the tree business, we used tons of the stuff, it did smell, but it also worked well. I also thought it got replaced for the most part.
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
