Looking For A Kind Of Pest Killer Spray - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 05-03-2010, 11:18 PM   #1
Looking for a kind of pest killer spray
A long time ago, a friend of mine used a kind of bug killer spray. But I forgot what it is called.
Basically it looks like the kind of canned spray like Raid. But you don't spray by aiming at the bug or bugs. Instead, you place the canned spray in the middle of the room, set it off and let it spray into the air. Of course, before you do so, tightly close the windows and then close the door and leave it alone for about 5 hours. And then a lot of cockroaches etc. are killed, lying on the carpet.
Do you guys know of bug killer spray like this? Where can I get it? Thank you.
userid is offline   Reply With Quote
Old 05-04-2010, 07:06 AM   #2
These are called foggers, most stores that sell bug killer like raid also sells the foggers
Very specific instructions as to use
Food items must be put away, pets not in the house
Read the instructions before use
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
BIN Spray Shellac-Base Primer formulation PAINTLOVER Painting 0 05-01-2010 09:54 AM
DIY spray foam kits HitLines Building & Construction 4 03-18-2010 12:58 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
Spray Paint Question Scrybe Painting 1 04-21-2009 07:11 AM
