Larva-Lur In Crawl Causing Problems - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 01-21-2013, 11:02 AM   #1
Rewards Points: 342
Larva-Lur in crawl causing problems
I used Larva-Lur in my crawl to get rid of cave crickets. It got rid of all the cave crickets just fine but a couple of weeks after I laid the stiff everywhere I put the Larva-Lur turned to little mold balls causing yet another problem.
A. How do I get rid of the mold balls?
B. How do I mitigate this problem so that it doesn't happen again?
tripower is offline   Reply With Quote
Old 01-21-2013, 12:50 PM   #2
Rewards Points: 13,446
Dirt floor, standing water, how is it vented?
Old 01-21-2013, 04:08 PM   #3
Rewards Points: 342
Dirt, no standing water, standard crawl vents.
Old 01-21-2013, 07:30 PM   #4
What harm are these balls doing?
You need to lay a layer of 6 mil. plastic on the ground and stake it down with 16" insulation hangers bent in half.
If not the rising moisture can cause mold, mildew, fungus. on the floor joist and subflooring.
Crawl Space Questions mark2741 Building & Construction 1 12-23-2011 11:20 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
Is 1/2inch pipe causing problems? MrSmythe Plumbing 4 08-25-2010 06:06 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
What is the proper ventilation needed? Ice Damns causing problems. alanisaacson Roofing/Siding 1 01-07-2005 01:38 PM
