Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 07-08-2008, 03:52 PM   #1
large flying ants on patio
This morning when I get out to work on the patio paver laying... I saw quite a few flying ants... most of them crawling on the ground... but some flying... I kill any I can by simply stepping on them... They are of those large size type, not those tiny small ants.... I worry they try to build new home under my paving stones... As for sure there are space underneath or in between stones..etc....
any advice to prevent them from achieveing this... will those poison from HD for ants (some liquid) (some power) work? or there is a better method...
KUIPORNG is offline   Reply With Quote
Old 07-09-2008, 12:24 AM   #2
Kap
Mowing my life away.
Where are you? Over here, they're termites. We get the annual hatching here. Looks like flying ants, but they're not.
Kap is offline   Reply With Quote
Old 07-09-2008, 10:04 AM   #3
yes they may be termite..... well this morning they didn't show up... may be due to the rain last night... well whatever... is there any preventive method I can use to stop them nesting under my pavers... right now I am not sure if they did that or will they intend to do that..etc.
thanks...
Old 07-10-2008, 02:00 AM   #4
Kap
If they are termites, I'd be more concerned with them nesting in the house than under the pavers. Maybe consult a pest control expert?
Old 07-12-2008, 03:52 AM   #5
747
registered
747's Avatar
Sounds to me like worker termites. I would get a professional exterminator out for a house inspection. Also he has a wand where he can saturate that soil around patio from underneath to kill them.
747 is offline   Reply With Quote
Old 07-14-2008, 09:23 AM   #6
After searching the net a little bit... I think that morning what I encountered is actually some ants' queens and kings try to mate.... our home was so lucky being selected as making bed for many times: two birds nests, one in the tree, one in a hanging flower pot... bumble bees under our stairs... now these ants thing.... I did kill a lot of queen that morning.. but for sure not all of them... that means I did do the earth some good by eliminating a bunch of ant potential colony....
why I think they are ants rather than termites:
1. this flying ants only happen in that particular morning and no more...
2. I remember the looks of it is kind of look what the web said regarding different appearance of ants and termites...
anyway... thanks for the reply... I would really nervous if I do see termites and definitely will do whatevery I can to eliminate them.... for now I don't see them no more... so I am good...
Old 10-29-2008, 11:02 AM   #7
You could have a mature carpenter ant colony. I am dealing with one right now. I opened a wall void to find hundreds of huge worker ants and a lot of swarmer ants. The swarmer ants have wings. If you can catch one, you can just look at its antennas and body to determine if it is a termite or carpenter ant.
bluefitness is offline   Reply With Quote
Old 10-29-2008, 02:09 PM   #8
as it only happen once in one morning... and never again... and I did some search on the internet and confirm that...
anyhow... I am now spend much less time doing renovation but passing Gospel... after reading the book "Heaven is so real"... give it a try... may be you need to drop all your equipments like me ... if you are DIyers like what I used to be...
Old 11-14-2008, 11:17 AM   #9
Termite swarmers are black and small termite workers are translucent and small and do not fly
It sounds like carpenter ant swarmers
The larger ones are alate female and the smaller ones are alate males
The one without wings have already mated
And yes they are attempting to establish satellite colony, possibly under the pavers
Go out at night with a flashlight and try to find a trail and follow it back to the nest
Once you have found that treat it with any pyrethrin you have on hand
Spent 25 years in Pest Control
Now I pull Raccoons out of peoples attics
ocoee is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Ants Ants and more Ants Hobb3s Pest Control 9 05-29-2008 11:26 PM
Advice:Pouring Concrete Patio steve65 Building & Construction 3 10-10-2007 07:57 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
