Ladybugs In New Construction ??? Concerned!!! - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 10-24-2010, 04:15 PM   #1
Ladybugs in new construction ??? Concerned!!!
In East TN, our home construction is in the framing stage. Felt on roof, but no shingles, windows yet. Almost all sheething up.
LOTS of ladybugs swarming now. I know the nights are getting colder and there are no "warm" places yet in the house. No places to hibernate as I would imagine they might need. Current temps are 70 day and 45 night.
Will we need to treat for ladybugs once we get dried in? Before insulation? Before anything?
I hate to think of a spring thaw that brings out literally thousands of ladybugs in our new home.
Thanks.
willp2010 is offline   Reply With Quote
Old 10-24-2010, 04:41 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
are you sure they are ''ladybugs''?im not scared of them
Tom Struble is offline   Reply With Quote
Old 10-25-2010, 06:06 AM   #3
pest control operator
The ladybug behaivor (asian ladybugs) that you describe can be accurately described as a force of nature, same as boxelders bugs, stinks bugs. They seek overwintering places in the fall, re-emerge in the spring to go back to the surrounding environment. It was happening before you built, and will continue. Spraying, probably every 3-4 weeks in the fall when the swarming starts will provide some relief, but will not stop the behavior. These guys fly in to your house, as opposed to the typical crawling insect that is easier to treat for. That said, I urge people to get used to them-you really don't have any other choice. When consistently cooler weather gets here, they will be in their overwintering places, until a warm and sunny January day when they think it is spring.
If you want to spray yourself, or hire someone, a good active ingredient is lambda-cyhalothrin. Look for the concentrate and mix it with water yourself. Compressed air sprayer, 1 gal or larger. Backpack sprayers, 3 gal or so are very helpful. Treat in all door/window jambs, frames, int and ext. Treat where siding meets the foundation wall, treat the immediate soil perimeter.
Brand names that have this active ingredient: Demand, Border, Cyanora, and possibly others. I've seen this active ingred in the big box stores, too, under various brand names. Read the label, look for "active ingredient".
PAbugman is offline   Reply With Quote
Old 10-25-2010, 06:18 PM   #4
Thanks PA. I know we will get swarms as a normal course of business where we are, and I can deal with flyers coming in next fall.
I guess my main question is do you think they will be able to hibernate in our house, given that winter is approaching and the current status of our build.
I really do not want them there all winter and literally crawling out of the woodwork this spring.
Old 10-25-2010, 07:30 PM   #5
I suspect that your temperate zone is about what we are here in southcentral pa. Apparently you're not going to have heat in the house so successful hibernation is questionable. I don't know at what temperature they actually freeze; not sure yet if anyone knows that. If they can get out of the wind, that would be an asset to them, but an unheated structure can get colder at night then the outside temps. During the day the sun would heat the structure enough. I guess it's all a matter of how cold it gets at night and for how long. I'm also guessing that my answer is not much help.
Consider treating as I described earlier. Also realize, that time will bail you out of this particular issue. If it happens, think of the stories that you can tell your friends about your new house.
Contractor pre construction retainer scorpious Off Topic 3 07-29-2010 11:32 PM
New Home Construction Question wikkie650 Building & Construction 8 06-14-2010 10:07 AM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing/Siding 21 03-26-2008 11:05 PM
Construction Nightmare - need help!! naper_home Building & Construction 5 04-06-2006 03:57 PM
