Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 02-18-2009, 01:36 PM   #1
Default killing spiders
I moved into a new house last month and I've already started seeing small spiders. What can I use? I have a 8 month baby at home so I want to use something that wouldn't cause any problems.
please advise.
Thanks,
kk
kirridam is offline   Reply With Quote
Old 02-18-2009, 01:57 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
Vacuum, newspaper
They like moist areas, maybe a de-humidifier would help
We have them all the time
Baby spiders are small enough to make it thru the window screens
Old 02-18-2009, 02:03 PM   #3
We had this problem too when we moved into our house. I tried all the spider sprays and even bug bombs from HD. They all worked for a little while but we would still see a few here and there so I called an exterminator. He sprayed outsid and inside and I think it only cost $100. and lasted for one year. Haven't really had to do any thing since then. That was 4 years ago. BTW I brought one of the spiders to our weed and pest control office to see what kind it was and they said it was a Black widow.The things would cover the whole outside of the gagage door in the evenings.
lsuchor is offline   Reply With Quote
Old 02-22-2009, 07:04 AM   #4
SxS
I imagine that most anything that would kill a bug is potentially harmful to your most prized posession; yet I'd like to offer something that has been working for me lately where contact wouldn't be an issue.
Went online last year trying to solve a multi-faceted bug problem; as we live on 16 acres of swampland and have now seen bugs that we obviously never even knew existed! Came across a company in FL. (who has more bugs than Floridians?) and they recommended this Delta Dust http://www.pestproducts.com/delta_dust.htm applied with this duster http://www.pestproducts.com/products/360dustwand.htm and a little Talstar http://www.pestproducts.com/talstar1.htm applied every few months or so. I also bought this fantastic little sprayer with a lifetime guarantee: http://kill-fireants.com/mcart/index...=IT265&code=13
Gosh, what a difference.
The duster gets into any nook or cranny that you puff it into (often several feet away, the dust will puff out) you don't use a lot of product... and it's pretty darn waterproof to boot! Hard to tell about the Talstar; yet I have pretty much solved my pisselm bug infestation; the carpenter bees are on the run and most other bugs have all but disappeared both in and around the house.
YMMV, but it was well worth whatever we paid and I'll be purchasing more very soon simply for backup or to try and help out others.
SxS is offline   Reply With Quote
Old 02-22-2009, 09:17 AM   #5
SXS,
Thank you! I'll try it out.
kk
Old 02-22-2009, 02:54 PM   #6
SxS
...if nothing else; there is a lot of info on that site about pest control in general (btw, I am not associated whatsoever with these people and simply stumbled upon this company).
Old 02-23-2009, 07:34 AM   #7
well you can use those pesticides ... make sure you do it when your child is at school or something like that and be careful it must not go to the foods...
blogo is offline   Reply With Quote
Old 02-23-2009, 03:28 PM   #8
Send a message via AIM to rh8868 Send a message via MSN to rh8868
I don't know if I'd wait til your child was at school, unless you've got him/her on a very accelerated schedule. Didn't you say the baby is 8 months?
rh8868 is offline   Reply With Quote
Old 03-25-2009, 01:31 PM   #9
MY preferred spray is Tempo. VERY safe as its labeled inside houses ,restaurants, and food processing places. Spray your foundation and outside area also to prevent ticks and other crawlies. You think that grass is green? It harbors lots of unsuspecting diseases in those bugs and critters.
4just1don is offline   Reply With Quote
Old 03-29-2009, 09:50 AM   #10
The fix is simple and fairly cheap
Treat the outside of your house by sweeping down any webbing with a broom designed for the task called a Webster
The treat the OUTSIDE of the home with Tempo WP or Demand CS (the formulations WP and CS are key here)
treat the inside of your home with Combat Roach Gel in the kitchen and bathrooms, spiders are there to eat other bugs, no prey no predators
Lower the AC 2 to 4 degrees to help dehumidify the home
The spiders may be there simply because they house was vacant for a period just living there will help tp drive them away
The pesticides used to day are basically designed to mimic chrysanthemums and pose little to no health risks when used properly
people became more chemically aware well after we stopped using the stuff they needed to be afraid of
I havw been exposed to more pesticides in a month than the average person would be in a lifetime with no health issues
For 30 years almost all my friends have been bug men
none have had any health issues that could be attributed to pesticides except the two that died of liver cancer, they were also alcoholics in their 50's
Spent 25 years in Pest Control
Now I pull Raccoons out of peoples attics
ocoee is offline   Reply With Quote
Old 07-15-2009, 10:58 PM   #11
Default do not kill spiders. just get rid of them by detering...
killing spider is not the solution. just prevent them from coming in, or make those critters run. how? by using organic, strong scent that spiders hate, peppermint oil. i read it on this blog below.
http://organic-oil.blogspot.com/2009...t-control.html
it says there are numerous of essential oils that get rid of pest, but does not take its life. another oil that pests hate is the citrus odor like lemon or orange oil.
overall using pesticides....very dangerous to your health.
ecofriendly pest control is the better way.
fred luu is offline   Reply With Quote
Old 07-29-2009, 03:43 AM   #12
Tom3982s
Default Organic pest control
Locally I called an organic pest control place for this, and let me say it was 8 months before I saw another! Stuff worked, beats that other toxic junk...
Tom3982s is offline   Reply With Quote
Old 07-29-2009, 09:30 AM   #13
011000100110111101101111
DangerMouse's Avatar
i use powdered basil, spiders hate basil as do most other insects.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
Old 07-29-2009, 01:37 PM   #14
Sticky Traps! Find where they enter! New house? Call up that general contractor and tell him to bring his bag of tricks! Spiders are tough to knock out with any chemicals they sell off the shelf and they don't sell the good stuff to the masses for good reasons so save your money and your health. How about growing crysanthemums outside since that's the base in all the organic pesticides used nowadays? Well, this one is a longshot as my wheels turn but I have just adopted a stuffed platypus, yes platypus! His name is Donald Cleaver, or just "Butch" for short. But I put him on my ceiling facing SW to Australia for giggles, but I do feel he's pissed off and is trying to find his way home! The poor guy....But hey I'm really thinking if anything is gonna freak out or confuse a spider right out of the house, this just may be the ticket girl! I'm really starting to think I may be the only person with a stuffed animal walking on his ceiling.......
woobiken is offline   Reply With Quote
Old 08-08-2009, 11:58 PM   #15
How do you apply the powdered basil for spiders? most I have are high up.
GoFins is offline   Reply With Quote
More On This Topic
Hi, I'm Teri Lynne and I'm here on behalf of Expert Village and in this segment we're going to be showing you how to play a game called Psychiatrist. This is a great guessing game. You need a minimum of two people to play this game. How you play is, you... Read More »
The Brazilian wandering spider (Phoneutria fera) is one the most dangerous spiders in the world and should never be kept by the casual keeper or handled by anyone since it is fast, aggressive and poisonous. This specimen is native to the northern part of... Read More »
Hi! My name is Austin Shepard and I am here with Expert Village. Today I am going to be talking to you about bugs on your plants and what to do about them. So let's say you are looking at your household plant and you notice either little white things... Read More »
Nothing is more annoying than bugs in a home. The following will help prevent and detour any unwanted visitors. Read More »
Hello, my name is Dr. Susan Jewell. I this clip I am going to talk to you about one way to neutralize some of the toxins or poisons that you get from certain bites like spider bites that will help to neutralize the poisons right away. Now one way to do... Read More »
Using tempo to kill spiders 4just1don Pest Control 12 09-24-2008 05:12 PM
Spiders in the backyard dankreboot Landscaping & Lawn Care 1 09-10-2008 07:58 PM
Railroad Ties Wall & Black Widow Spiders Dona Pest Control 4 09-06-2008 06:04 PM
The SPIDERS are COMING! Taipans Pest Control 44 05-08-2008 09:00 PM
Tree Stump Killing Grass? malsup Landscaping & Lawn Care 3 12-14-2007 10:24 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
