Insect Repelling? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-21-2011, 03:07 PM   #1
Rewards Points: 97
I have a closet (crawl space?) in the basement that looks like it can potentially be a habitat for spiders and other insects. We want to use it for storage but don't want insect webs and other critters crawling all over them. The room has no power. It is dark but I'll get a battery operated light for that. Basement is a bit humid. The room is constructed out of wood.
What can I use to repel critters from living in this room? Will moth balls work?
edta1 is offline   Reply With Quote
Old 07-21-2011, 04:45 PM   #2
pest control operator
Is this an actual room with a door? I ask because a crawl space, too me, is like a mini-basement with very low head room.
If this is a room that has a door that can be closed, then I suggest the yellow, rubbery insect strips that you can hang from a hook. The active ingredient will be something like Vapona, Dichlorvos, DDVP. The insecticide is time released into the space. You don't want the air to change too much when using these as it would dilute their effect. Change them as required by the label. If no door on the room, you could hang a shower curtain, blanket, etc.
They can be bought at farm supply stores, hardware stores, etc.
PAbugman is offline   Reply With Quote
Old 07-21-2011, 05:17 PM   #3
Rewards Points: 97
Thanks. I just checked with home depot and they don't carry it. It's a farm specific item then?
Old 07-22-2011, 04:51 PM   #4
Our local HD and Lowes carry it under the "Hot Shot" brand.
Active ingredient: Dichlorvos
flying insect identification please trails Pest Control 7 07-03-2010 11:23 AM
wood eating insect identification autx790 Pest Control 4 09-17-2009 09:02 AM
What products are best for repelling geese or duck s from my grass? shanemcguire1 Pest Control 9 08-07-2009 10:19 AM
insect pests in the home that bite tomsjule Pest Control 24 06-15-2009 11:45 AM
Insect/ debris filter for air inlet Ernest1 HVAC 8 02-06-2009 02:03 PM
