I May Have A Raccoon In My Fireplace Chimney - Pest Control - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 06-21-2013, 02:05 PM   #31
Originally Posted by bucksone View Post
I had a similar problem a few years ago, and an animal control officer I knew suggested the amonia trick. Worked like a charm. Also, for what is it worth, here in Ohio, if you trap a raccoon you have to either kill it or release it on site. It's against the law to transport it anywhere to release it. The concern is the spread of disease.
Thanks,
I've bombed the chimney with ammonia soaked face cloths (strings attached to help reomve later).
The Raccoon must be wearing a gas mask!
He's still there.
Unicornz0 is offline   Reply With Quote
Old 06-21-2013, 02:07 PM   #32
Originally Posted by Oso954 View Post
The risk of nesting materials or feces in your chimney is those materials igniting into flames. With some creosote in the chimney, you get a chimney fire which can spread into a house fire.
How many years have you gone without a chimney cleaning/inspection ?
Now would be a good time. And yes, most of them will install a animal resistant cap if you want them to perform that work.
I just got the house.
It came with the Raccoon, no additional charge
Old 06-21-2013, 03:22 PM   #33
Oso954's Avatar
Rewards Points: 1,298
Another great reason to have it professionally inspected and cleaned.
And no, just because you may have had a home inspection, it does not mean that the inspector looked at the interior of the chimney.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Unicornz0 (06-21-2013)
Old 06-21-2013, 06:53 PM   #34
Rewards Points: 1,062
Originally Posted by sdsester View Post
. Be mindful of razor sharp claws and teeth.
What traps are you referring to? Razor sharp? What brand of manufacturer sells steel traps with jaws which have been sharpened like a razor? And teeth have been outlawed on steel traps for decades in most states.
No trapper would ever want a razor edge on the jaws if trapping raccoon for fur. The force of the jaws would immediately slice the paw allowing the coon to run away. The saying is "there is no profit in catching feet".
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-21-2013, 06:56 PM   #35
Originally Posted by Unicornz0 View Post
Thanks,
He's still there.
You are probably not using the correct strength of ammonium hydroxide. Did you buy grocery store grade? Too weak. Go to Ace hardware, and ask for industrial strength ammonium hydroxide (ammonia). It is about 10-11%. While that sounds "weak", I assure you you will be knocked off your feet if you take a wiff. Pour that into a spray pump and spray a rifle stream up into the chimney while using a carbon/charcoal mask!
. Try that. Also, you can pour some into a wide pan and prop it up into chimney somehow, then plastic tape off the face of the fireplace well!! Repeat over and over, and the coon should go away.
Old 06-21-2013, 08:13 PM   #36
Thanks,
That Raccoon must have a gas mask!!!
Old 06-22-2013, 12:04 AM   #37
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
There's city peeps who have to PAY big money to see wildlife at the zoo or wildlife park, and travel some distance to get there, but you get the views and experience right there in the comfort of your home, and for free too
Best take a read of my previous post with the information on what to do/not do.
RWolff is offline   Reply With Quote
Old 06-22-2013, 01:31 PM   #38
FClef's Avatar
Rewards Points: 160
Won't your local Animal Control person come out? They do stuff like this all the time and they normally work for your county or city or township.
FClef is offline   Reply With Quote
Old 06-25-2013, 09:49 AM   #39
Not for this.
Old 06-25-2013, 09:56 AM   #40
The pest control company came & installed a chimney (flue) trap yesterday.
The Tech said he couldn't see the Raccoon, it's about 30' to the fireplace damper.
I wouldn't let him spray an irritant to rouse the Raccoon (probably wouldn't have worked anyway, since he sleeps with a gas mask).
The trap has not been tripped as of this morning.
Maybe, I don't have a Raccoon in the chimney after all.
Maybe it's Wiley Coyote!
Old 06-25-2013, 06:25 PM   #41
747
registered
747's Avatar
Rewards Points: 534
You did the rite thing. A mother raccoon is nothing to mess with. They will attack.
747 is offline   Reply With Quote
Old 06-29-2013, 08:31 AM   #42
Too Short? Cut it Again!
Hopefully the beast has moved only to look forward to tearing apart your trash bins. If it was a squirrel or something? A squirrel tore apart the car wiring of my Godparents to the tune of $4K once. They had parked the car outside while I was doing some work for them and storing lumber in stuff in the garage. The breed was brought to beautify the University of Illinois campus. They have no real predators and are so cute until they turn pest they just multiply.
I do think for reasons beyond the animal in the chimney and given this is a new house? And especially if you plan to use the fireplace, call a chimney sweep. I always advised clients to do so annually. If there is leftover animal nest material in your chimney, you probably do not want to bring hot sparks near it?
"But they are expensive!" And yes I guess good ones can be but they are much, much cheaper than a chimney originated house fire.
And of course let us get back to the fact the critter probably got in because of a missing chimney cap. Pay the money and buy a good one. A chimney sweep or mason can be helpful in your choice. An orange apron box store employee will have no idea of what your are asking about.
One final piece of good news. Critters are habitual and they pass what they learn generationally---even dumb as rocks squirrels. If you had problems with one and it found a comfy place? It will be back with friends when it turns colder again.
Old 06-29-2016, 01:58 PM   #43
Rewards Points: 146
Re: I may have a Raccoon in my fireplace chimney
I had a raccoon in my chimney. Turned out that it was a mother and babies. The Wildlife company got it out by lowering a ball (maybe a tennis ball) covered in the scent of a male raccoon (apparently, the males eat the babies). The raccoon came running out immediately with one baby in it's mouth. I was informed that it would be back for the others. Don't you know that in the early evening, I'm sitting in my recliner watching TV (near the fire place/chimney) and I hear this unGodly sound. Freaked me out. It was the mother coming back for the babies. Apparently she took them out. So, if you can find out where to buy that scent... your're all set. Cost me a pretty penny. Now have chimney caps.
Jacke is offline   Reply With Quote
Romex wiring distance from from fireplace Chimney bricks? Ocelaris Electrical 6 01-10-2013 10:40 PM
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
fireplace and chimney top rebuild??? syborg Building & Construction 18 01-16-2010 02:58 PM
