#1 |
Huge house with tons of 'dead' area in attic
I have squirrels, birds, bats, flies, mice - all kinds of **** in my attic. I've been live-trapping the mice for a couple weeks and think I finally got them all, but I think the problem is just how my house is made.
Basically, there is a big gap between the outer walls and the inner plaster. The inner plaster is tore apart, so it doesn't keep pests out, but it does keep you from getting at them. Also, my house is really tall - like three stories high. There is metal on the outside that I can really get to and squirrels have eaten holes in the upper part of my house to get it. I tried trapping the squirrel but can't get him. There is a tree by my house that he uses to get in - it's like 100 years old, my nicest tree, hate to cut it down. My plan: - Remove all of the lath board plaster - Spray foam the walls from up top - Roxul the underside of the roof (would spray foam be better?) - Try and fix the metal from the outside - No idea whether I should plaster or leave it as insulation. I hate to leave a cavity for animals to nest in, even if it is filled with insulation. The house has blow in insulation now. They say it is supposed to deter pests, but it doesn't, they build nests right it. They even nest in fiberglass insulation, which you think would be itchy / poisonous. |
#2 |
You need to call and contract a good, licensed exterminator or, I guess spend much more tenfold on household remedies.
Your job, once the exterminator is done, and even before, is to identify how all are getting into your home and fix and repair all inbound and outbound access points. |
#3 |
pest control operator
Sounds like a lot of work to do on the house, especially the outside. The squirrels are creatures of habit and will continue trying to access the house even after repairs. They need to be removed and maybe the tree cut down. Trapping squirrels is hard-they are smart and cautious. If you want to diy carpenter ants then I reccommend using an exterior spray/treatment that has the active ingredient “Fipronil”. Commonly known under the Termidor brand, I am seeing it under other brands now as it must have come off patent.
#4 |
paper hanger and painter
I would let the damn squirrel have the attic before I would cut ANY tree down.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 | |
Huge house with tons of 'dead' area in atticQuote:
Yeah Chris. The guy who did concrete for me in Central Illinois was also a licensed trapper. By law you have to shoot some things here. One visit to his place would convince you he was not trigger happy. Or remains a really bad shot at point blank range. None of the critters running around were in his house. You can trap, exterminate and all until the cows come home and nest in your attic. If when the exterminator or trapper is done, and you don't patch ingress and egress points? You deserve what you get. Never been cornered in a situation I could not get out of yet by an attic squirrel. Once I was living in and restoring an antique home and this paw managed to make it through whatever ceiling material. Mitzi-Soprano and Cleo-Catra heard the puncture before I did and for days, I swear they thought they were in Disneyland. 24/7. It became them or the squirrel. Cat math was going on in their heads. I just watched them. Until I could not take it anymore. I had the attic sprayed with "essence of fox" or something and as critters leaped from the attic? Friends and I watching knew exactly how they were getting in and out. Last edited by sdsester; 11-17-2011 at 09:36 AM. |
#6 |
I would take concrete steps of sealing all entry and exit points so no more creatures can get inside or leave. Use food as bait to catch the remaining creatures inside. Then fill in the gaps in the attic.
#7 |
Yeah, you def need to patch the holes they are using to get in. I did this once with that sprayable expandable foam....mice eat right through it! I had to use something called Stuff-It, looks like copper steel wool.
I had a small mouse problem recently, and the exterminator came and plugged up holes where the house sits on the foundation. He also put something outside called a "rodent rock". I don't know much about it, except I think it is like an attractant for the pests thinking of going in to your home, so they go to this plastic rock first, and eat the poison in it. Smetimes a decent exterminator will save you tons of time and money. |
#8 |
I totally disagree. A decent exterminator WILL ALWAYS save you tons of time and money. They have access and licenses to use stuff the consumer cannot---thank goodness. Most household pesticides are but marketing gimmicks with limited effectiveness. We spend a chunk on the pretty packaging each year and usually end up calling an exterminator anyhow. Why not just start at the end point in the first place?
| Display Modes | |
| Bath fan venting runs through attic and out side of house | ponch37300 | Kitchen & Bath Remodeling | 4 | 09-24-2011 05:07 PM |
| One by one all outlets in house go dead | Sheeblee | Electrical | 5 | 08-23-2011 10:22 PM |
| Frost in the Attic | 295yards | General Discussion | 13 | 12-07-2009 05:27 PM |
| New house, "power vent" in attic is loud! | RyanD | HVAC | 7 | 05-26-2009 04:23 PM |
