How To Screen Off Open Pipes To Keep Stinkbugs Out? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 08-28-2011, 05:48 PM   #1
How to screen off open pipes to keep stinkbugs out?
Brown marmorated stinkbugs overwinter in my house and having to chase/collect them is very tedious so, I'd like to keep them from coming in. There are a couple of things that I can't really figure out how to screen off with 1/8 hardware cloth. One is a 6" PVC elbow pipe outside, which lets air into the fireplace. Another is a flexible duct open to the attic, which is constructed similar to a vacuum cleaner hose but is made of aluminum and somewhere between 4" and 6" diameter (it's an exhaust vent for an upstairs bathroom).
Stinkbug H8r is offline   Reply With Quote
Old 08-28-2011, 06:17 PM   #2
fabrk8r
fabrk8r's Avatar
Both of those pipes should have back-draft dampers that should seal tight enough to keep the bugs out when the appliances aren't being used. If the backdraft dampers are not installed or aren't installed correctly you are losing a lot of heat in the winter.
The next thing you need to do is vent the bathroom exhaust properly to a correct vent hood on the exterior or roof of your home. Venting a bath exhaust into your attic can cause mold and structural damage.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-28-2011, 09:25 PM   #3
I'm not sure I can install back-draft dampers in these areas but, even if I did do that, the stinkbugs might even squeeze in between the closed slats. So I would even like to screen those off with 1/8 hardware cloth. If anyone has any ideas on how to screen off open pipes with hardware cloth, I'd love to hear them.
Old 08-29-2011, 06:52 AM   #4
fabrk8r
fabrk8r's Avatar
The correct vent hood for the bath exhaust will have an aluminum single balde backdraft damper with foam gasket already installed as well as hardware cloth, although it will be 1/4" spacing to keep birds out.
You can make your own hardware cloth screen for the intake pipe and use a large hose clamp to secure it to the PVC pipe. Just be sure to check it frequently for obstructions.
There will be more people telling you to get the bath exhaust situation corrected before any major damage is done to your attic.
Questions about open cell foam howdihi Building & Construction 2 09-09-2010 09:40 AM
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 01:17 PM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 05:31 PM
How to Check Old Pipes? margog85 Plumbing 1 01-19-2010 06:01 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
