How To Keep Wasps From Building Nests Inside Storage Shed? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-13-2013, 06:31 AM   #1
r0ckstarr's Avatar
Rewards Points: 2,060
How to keep wasps from building nests inside storage shed?
I have a shed in the back, and it seems that wasps like to get in and start building nests. I've been keeping up with them, and killing them as soon as they start building, but more keep showing up each week. I killed 2 more yesterday. I've noticed that it's two types. Red wasps and yellow jackets.
I've checked to make sure that every crack and crevice was sealed, but they enter through the spinning vent on the roof of the shed. At one point, they were building a nest inside the spinning roof vent. Every time the wind picked up, and the vent started spinning, they would swarm around.
I took a can of wasp spray and sprayed it along the inside of the roof and area's where they would build a nest, but the effect seems to wear off.
r0ckstarr is offline   Reply With Quote
Old 03-13-2013, 07:06 AM   #2
Ok ..don't knock it until you try it..
A baggie with a handful of pennies with water in there suspended from the rafters. Try a few in different locations.
They think it is another nest and leave.
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
r0ckstarr (03-13-2013)
Old 03-13-2013, 07:11 AM   #3
Rewards Points: 1,648
Cover the vent. If every crack is sealed the vent has no value.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 03-13-2013, 07:41 AM   #4
Rewards Points: 1,476
If you want to keep the vent you can put a screen at the bottom of the opening. They will still go into the vent, but not into the shed.
mikegp is online now   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
Old 03-13-2013, 10:21 AM   #5
Rewards Points: 13,960
Remove that vent and install a ridge vent.
Old 03-13-2013, 03:38 PM   #6
Rewards Points: 194
Unless you have a vent that is screened they are going to keep coming in and you will have to keep removing them. And when you remove the vent they come in from they will just start building nests in the overhangs or someplace else and you will have to keep removing them. The battle never ends I have found.
Larryh86GT is offline   Reply With Quote
Old 03-13-2013, 03:53 PM   #7
Do not toss away the idea of pennies in a baggie of water. Quick, easy and cheap
It only takes a couple of days and their activity ceases. They just won't come around anymore
Old 03-13-2013, 07:29 PM   #8
Rewards Points: 258
A screen at the bottom of the vent is the easy solution.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
The Following User Says Thank You to retired guy 60 For This Useful Post:
Old 03-13-2013, 09:52 PM   #9
r0ckstarr's Avatar
I can't believe that I didn't think about screening up the vents. For some reason, I was thinking chemicals and pesticides. Thanks for the ideas! I'll definately put some screen up, and just for good measure, a sack of pennies as Creeper requests.
The Following User Says Thank You to r0ckstarr For This Useful Post:
creeper (03-13-2013)
Old 03-13-2013, 11:21 PM   #10
in water
Old 03-14-2013, 05:22 AM   #11
r0ckstarr's Avatar
Of course.
I may even put one of these on a shelf in there.
Old 03-15-2013, 07:23 PM   #12
Rewards Points: 986
http://www.snopes.com/critters/wild/flies.asp
Toller is offline   Reply With Quote
Old 03-15-2013, 08:01 PM   #13
r0ckstarr's Avatar
Originally Posted by Toller View Post
Their test says that it was done in indoor lighting, and that they haven't actually tested it in sunlight. Either way, it's always dark in my shed.
Building a shed, need some tips. humberguy Building & Construction 5 03-30-2012 06:38 AM
Stick building a 12x12 shed roof. toogiggly Roofing/Siding 2 09-28-2011 08:19 PM
Building shed on a slope Augy Building & Construction 1 05-05-2011 07:03 PM
building a shed boddah Building & Construction 11 03-21-2008 04:35 PM
Painting the inside of a storage building MillerClemsonHD Painting 6 03-23-2007 07:23 AM
