Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 10-08-2008, 08:50 PM   #1
House Flies
I live in North West Indiana. Currently the weather is mild and a bit rainy. I seem to have an infestation of houseflies. They seem to be your run-of-the-mill black housefly (black body and red eyes).
They are concentrated in my basement. There are a couple hundred of them. They seem somewhat lethargic and don't move around much so fly strips aren't working very well. I have no idea where they came from. I was just down there two or three days ago and there were no problems. I don't smell anything rotting upstairs or in the basement. I have never had a fly problem before or any problems with any kind of pests.
I know that I can kill them off with a couple of bug bomb foggers. I guess my real question here is: where did they come from? Also, if I kill off this batch will another 'generation' be born in a couple more days.
lydokane is offline   Reply With Quote
Old 10-09-2008, 08:15 PM   #2
House Flies
They are breeding in some sort of decaying organic matter
Could be a body of some sort of stagnant water
Check any cracks and crevices soewhere there is something contributing to them
It could well be outside and they are coming in through a crack or bad screen
Spent 25 years in Pest Control
Now I pull Raccoons out of peoples attics
ocoee is offline   Reply With Quote
Old 10-10-2008, 09:05 AM   #3
RippySkippy's Avatar
House Flies
How tight are your basement windows/walls. This time of year house flies will find the smallest way to get into a warm spot to try an winter over....find the hole(s) plug them and you'll be good. Vacuum the rest up.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-21-2008, 10:44 AM   #4
House Flies
Probably a dead mouse or rat. They don't smell too much because they are small and decay quickly.
The flies are lethargic probably because it is cool. Flies need heat to be active.
Flies live off rotting organic material. Find that and you will find your source. If you don't find it they will eventually die off as the organic material is eaten and there is no more food for them.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 02-14-2009, 09:37 AM   #5
House Flies
Good morning.. The fly problem you describe sounds like something I've been dealing with since moving to the country 2 yrs ago.. It sounds like you have what are called "cluster flies" not house flies.. These look almost identical to the common house fly. They are not the waste eating bacteria laden flies you're thinking of.. I had an exterminator come out and spray in the fall last year.. The spraying has to be done in the spring and or fall to keep these flies at bay.. They are parasites to earthworms and that's where they breed.. In the ground not in your house.. Jump on google and search "cluster flies". Theres lots of info out there on what they are and how to handle them.. Hope this helps..sb
golf12 is offline   Reply With Quote
Old 02-19-2009, 12:47 PM   #6
John Canning VP
House Flies
It is always best to have the fly properly identified (insect identified) then you will know what you are dealing with. Where to look and what is the best treatment and or prevention method to use is determined by the specific insect. To get them identified, take a few good samples (in a protective container like a jar) to your cooperative extension agent in your local area. If they cannot ID them, they will give you directions to get your flies properly identified. That is the first step. When you have a positive ID, then you can plan your treatment and/or prevention for the next season. Cluster Flies could be your fly; if so a preventative treatment would be based on the specific emergence time for your local area and directed to the outside of the structure.
Sincerely
John Canning VP www.EconomyExterminators.com
john Canning is offline   Reply With Quote
Old 02-20-2009, 03:02 AM   #7
perpetualjon's Avatar
House Flies
Just reminded me of a "demotivator" poster I did...
perpetualjon is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 08:01 PM
help me solve this mystery please lindaberrien Roofing 17 06-12-2007 02:06 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
