-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Honey Bee or Hornets? (http://www.diychatroom.com/f51/honey-bee-hornets-171245/)
miamicuse 02-06-2013 06:28 PM
3 Attachment(s)
This property in Miami has a hole in the exterior coral rock fascial.
There are some kind of bees flying in and out of the hole. Probably a fairly large size nest. I count about 20 or so swarming outside, and constant traffic entering and exiting.
Is the yellow stuff honey?
What is the proper way to get rid of this?
http://i173.photobucket.com/albums/w...psd3ef7268.jpg
http://i173.photobucket.com/albums/w...ps972d5877.jpg
http://i173.photobucket.com/albums/w...ps6273ec87.jpg
joecaption 02-06-2013 08:16 PM
Just looks like yellow fungus to me.
http://www.bing.com/images/search?q=...ngus&FORM=IGRE
gobug 02-06-2013 10:18 PM
The first pic looks like a few bees at the slot entry. The other stuff is a mystery to me. A bee hive at this time of year probably has about 20,000 to 50,000 workers. The hive itself for a mature colony could be in a wall and take about 8'x8'. If the hive goes into the rafters instead of the exterior wall, it is a mystery.
Honey bees in the ceiling is a serious problem. They are very difficult to remove, and the honey will ooze down through drywall once the bees are gone.
I suggest that you call a bee keeper, not an exterminator. As an exterminator, if I had to remove bees in your structure, it would cost hundreds depending on circumstances.
Good luck
Gary
Maintenance 6 02-07-2013 11:00 AM
Honey bees are smaller than hornets and usually fuzzy. Every hornet I've seen builds a paper nest suspended from something with the entrance at the bottom. Honeybees will nest in a wall cavity.
CarpenterSFO 02-10-2013 02:15 AM
Call a beekeeper - they're easy to find on-line. If there's a way for them to figure out how to get the queen and therefore the hive, you may get some free honey out of the deal.
mgp roofing 02-11-2013 03:57 AM
Looks like honey bees to me, the yellow stuff looks like someone tried to fill the hole with expanding foam from a can. That stuff goes that colour when its been in the weather for a while.
AllanJ 02-12-2013 08:56 AM
An adult honeybee has a black body with an orange side to side stripe on the abdomen (third section), also it has brownish hair. The honey is stored in wax honeycombs with cylindrical (actually hexagonal) cells.
An adult yellowjacket is black and hairless but with a lot of yellow on the abdomen and some yellow on the head and legs.
Hornet refers to several wasp species; most adults are mainly black and hairless, sometimes with thin yellow or white side to side stripes. Most make paper nests with hexagonal cells to hold their young.
The young (larvae) are grub-like or maggot-like and whitish.
Modern beehives have a grid in the middle that confines the (larger, egg laying) queen to the lower section so the honey that is harvested from the upper sections is not commingled (or contaminated) with the young.
Even a small hornet's nest can have a dozen or so hornets flying around it at times. It only takes a few weeks for a new brood of adults to grow so if you want to exterminate them only by spraying or swatting the ones outside, you need to be consciencious and attend to it several times a day.
Westies 03-06-2013 12:59 AM
Honey bees or hornets?
Good views here, I agree and think your invaders are honey bees and an area beekeeper might come to capture them (ask your county Cooperative Extension Agent). However that person likely won't want to be messing with your structure, ripping off sheathing etc. Maybe the nest is a foot up the wall.
If you simply spray to kill the bees you may have a lot of combs (wax and honey) which could attract mice, moths, etc. or decay and smell. Or it coud be a tiny young nest of no consequence. The beekeeper could tell.
As far as insect sprays go on yellow jacket nests, I find those wasp killer shot sprays are very toxic and a single spray of two seconds at the nest (paper type or entrance hole in ground) is adequate. Best to use all poisons sparingly.
Here (Penna.) we often find a longer brown wasp making paper nests. They'll sting if you bother them close but they are not as aggressive as yellow jackets. I just leave them be unless if in the worst site.
