Help- Bugs In Wall - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-13-2008, 01:19 PM   #1
help- bugs in wall
We noticed our recently painted kitchen walls looked weird so we thought the painter has applied the paint too heavily but some areas felt puffy and were cracking so we pulled away the paint and found rotting wood crawling with little worm like bugs (they are tiny/cream colored)! I am so upset, what could this be? Part of it is where there is an overhang over bay window and part of it is the windowsill. Even adjoining wall on that side looks suspicious
anneh
anneh is offline   Reply With Quote
Old 07-13-2008, 11:22 PM   #2
bofusmosby's Avatar
I am no expert, but it sounds to me like you have termites. By it being located in the kitchen where there is water, they could be subteranium termites. You need to call in an professional. These can do a lot of damage in a relatively short amount of time.
bofusmosby is offline   Reply With Quote
Old 07-14-2008, 09:27 AM   #3
thanks for responding. My main concern is that we don't want dangerous chemicals in our home, my husband is in remission from cancer. I have calls in to professionals.Are there ways of eradicating termites that are fairly safe? anneh
Old 07-14-2008, 11:11 AM   #4
bofusmosby's Avatar
I wish I knew the answer to that. The professionals should be able to answer your questions I would think.
Old 07-15-2008, 12:30 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Those are terminates. Don't worry about your husband. The stuff they use won't affect him. They actually drill through the foundation and inject there. They will also probably install perimeter baiting systems around your house. These things can do a lot of damage. Hopefully the top and bottom sills are still sound so you can just sister in some 2x4 to the left or right of the damaged ones.
747 is offline   Reply With Quote
Old 07-15-2008, 01:59 AM   #6
Rewards Points: 2,906
Anneh:
There has been a very important breakthough in dealing with termites, and it was developed by Dr. Tim Myles of the University of Toronto. http://www.utoronto.ca/forest/termite/termite.htm
The "trap, treat and release" method of termite control involves making termite traps out of strips of cardboard, allowing the termites to find those traps, treating the captured termites with a slow acting insecticide, putting them back in the trap and putting the trap back in it's original location. Normally, the termites will return to their nest to tell the other termites where they can find soft cardboard food.
Termites groom each other. When the treated termites return to their nest, the other termites will instinctively lick the insectide off their bodies, thus killing hundreds of termites for each "treated" termite that returns to the nest.
The City of Toronto is now using Dr. Myles "Trap, Treat and Release" method to rid entire neighborhoods of termites, and the program so far has proven to be very successful.
And, all the information you need to eliminate the termites yourself is available from the "Urban Entomology" web site linked to above. Or, even just phone up Dr. Myles and get an update on their success at eliminating termites in Toronto.
Nestor_Kelebay is offline   Reply With Quote
Old 09-12-2008, 06:18 AM   #7
Hi Anneh:
Termites are very frustrating and having to use toxic chemicals in your residence is a scary solution.
First you might want to be sure of what kind of termite you are dealing with. You can find some useful info and pictures about that here: Drywood Termites
Also there is a new treatment where I believe the termites are heated to death and there is no moving out required and no pesticides or toxic chemicals involved. You can find out more information about that here: Thermapureheat
Good luck!
--Andrixx
andrixx is offline   Reply With Quote
Old 09-13-2008, 12:13 AM   #8
Rewards Points: 180
yep those sound like termites
Especially in a bay window, those were the most problematic areas my former company dealt with
The new product they use for liquid treat is the same stuff that you buy to treat your dog for fleas it's called Premise
There are also many different baiting products out that work well for cures but I do not trust for prevention
be sure you get a REPAIR guarantee
Retreatment guarantees are not much better than useless
Also get at least three estimates and if at all possible wait till Novemmber to agree to service
In the winter sales are almost non existant and they will have to deal with you
In the spring they won't even return your call for a few days while they run around selling all the emergency calls that are coming in
The termites will not destroy your house in just a few months
They do about two linear feet of damage a year
Spent 25 years in Pest Control
Now I pull Raccoons out of peoples attics
ocoee is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
