Frass Behind Wall - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 02-10-2014, 08:46 PM   #1
Rewards Points: 61
Question
Frass Behind Wall
I had a water leak at the manifold accessed via bedroom on the opposite side of the wall from the water heater. I noticed what appears to be an almost soft soil like substance around the incoming pipes from the concrete slab. I did find termites last year and had the place treated with Termidor, haven't seen as much as an ant since.
Hopefully this is old if it is termites or ants but just wanted to get some opinions vs calling out a pest control company to verify.
aidan80 is offline   Reply With Quote
Old 02-11-2014, 05:15 AM   #2
Rewards Points: 14,006
Are you talking about all that dirt looking stuff that looks like it's laying on the slab?
Seeing any hard mud tunnels?
Hard to tell from the picture, is it just sand or saw dust mixed with sand?
I've never seen termites just haul in dirt like that.
Adding your location to your profile by going to quick links to edit might help narrow it down to what it might be.
Old 02-11-2014, 10:41 AM   #3
Rewards Points: 61
No mud tunnels, then again i had a water leak in there that may have wanted away any evidence. It feels soft like damp potting soil. I'll take a closer look when i get home. My thought was termites or carpenter ants but I'm far from an expert. The property is in Florida, i had termites on the outer wall in the same area last year which where treated with Termidor. Termidor was used, full 360 and drilled into the slab. Since then I've not seen as much as an ant in or on the house.
Old 02-17-2014, 08:10 PM   #4
Rewards Points: 61
Ok now that everything is fully dried out in the wall.. and it's time to repair the hole I vacuumed out the sand. I'm saying sand because that's the exact consistency of what I have. There's no sign of mud tunnels (thank god) or any insects of any type back there. No obvious damage to any wood. Just a small mound of sand at the bottom of the pipes. Almost exactly like I'd find in the yard when I spot an ant hill. I assume an ant hill popped up inside the house at some point in time?
This is what I found.. you may want to click on the image to get it full screen. All I can see here is sand and random bits sucked up from behind the wall.
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
