#1 |
Engine Exhaust/Carbon Monoxide/Chipmunks
I see there are some kits you can purchase on the web that enable you to connect your vehicle exhaust to a hose, and then place the other end of the hose into the chipmunk (or gopher or mole) tunnel- then hopefully cause a permanent sleep.
....but that shouldn't work so well if your vehicle is newer than 1974, as catalytic converters convert carbon monoxide into carbon dioxide? So am I missing something or are these kits a rip off? In fear of a rip off, I am instead considering using the gaoline engine of my pressure washer to be the source of my carbon monoxide. Here is my question. The engine exhaust of my pressure washer is round and one inch in diameter. I need to come up with some means to attach a garden hose to the exhaust. Obviously, whatever sort of "fitting" I devise must be able to withstand the high temps of the engine exhaust, while also not transferring any high temps to my garden hose. Does anyone have any ideas on how I can accomplish this? |
#2 |
Why the need to murder the cute little fuzzy if you don't even know what it is . If the only problem is that there is a couple of holes on your grass, why not just learn how to cope? You may even learn to enjoy its presense
#3 |
Stay-at-home GC
Like Creeper said.....
buuuuutttttt, if you just can't stand the little bastards, Carbon Dioxide is just as lethal as Carbon Monoxide as it displaces the Oxygen in low lying areas.
Can correctly identify Shinola 3 out of 5 times* *Under ideal conditions Some days, my Life needs a Rewind/Erase Button. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Why the need to murder the cute little fuzzy if you don't even know what it is...
[Life is sometimes not so simple. I have an INFESTATION of chipmunks that is destroying my property.] If the only problem is that there is a couple of holes on your grass, why not just learn how to cope?... [see above- I have "coped" for years and they are now overunning my property. My yard is FULL of holes and this is now damaging a retaining wall. I have tried live trapping for months and have only caught one chipmunk - but multiple birds) You may even learn to enjoy its presense.... (...Kumbaya!..... I am correctly visiting a PEST CONTROL forum, How about you? Under the circumstances I cannot enjoy their presence. If the situation should change, I will plan to visit you on the "Chipmunks as Pets" forum. |
#5 |
Stay-at-home GC
You could just put your reply near their burrows and kill them
![]() We're all friends here no need to get testy....
| The Following User Says Thank You to CplDevilDog For This Useful Post: | creeper (05-18-2012) |
#6 | |
Engine Exhaust/Carbon Monoxide/ChipmunksQuote:
Excuse me now I have to go put on my daisychain headpiece and dance barefoot in the meadow |
#7 |
It was a dark and stormy
Suck them out with a high CFM ShopVac. Here's how to figure out what tunnel windspeed you need to pull these little muthas out.
http://k7nv.com/notebook/topics/windload.html This method may collapse all tunnels. Do not overheat the vac or get yourself on the evening news. If they manage to hold on they will have to learn to breathe in a partial vacuum. Maybe with several 'applications' they will go elsewhere; I sure would. Or you could pump talcum powder into the holes and asphyxiate them. People have died in wars from the dust raised in houses or tunnels by bombs dropping nearby. No structural damage. Last edited by Yoyizit; 05-18-2012 at 03:51 PM. |
#8 |
Maybe time to inherit a small terrier that was bred for hunting/chasing/eating just those kinds of small mammals. A dog is so effective, although, may not get 100.000% of them. Yes, youll probably be stuck with the dog- as they may come back if the presence of the dog is gone.
Alexander Pope: [a little knowledge can be a dangerous thing] |
#9 |
Cat converters do not convert CO to CO2. They burn of excess hydrocarbons and convert harmull Nitrates of Oxide to harmless elements. Your car still put out CO just it always has. As for eliminating chipmonks...A 5 gallon bucket 1/2 full of water with sunflower seeds floating on top is a great way to eliminate them. I had a problem a while back with damage being dome to my home rom them and traps did not work.
#10 | |
#11 |
rodents love them and since they can't swim......
just make sure you check the bucket daily |
#12 |
Time for me to watch Caddyshack again
#13 |
danpik's method works very well, but they will return when you stop. You need to eliminate their food source for a long term solution.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it. |
| Display Modes | |
| Synthetic oil changes | leonuug | Automotive Repairs | 29 | 03-18-2012 06:49 PM |
| Snow thrower engine problem | KE2KB | Automotive Repairs | 19 | 11-22-2011 01:16 PM |
| Snowblower engine problem | TKE174NH | General Discussion | 2 | 12-15-2009 09:18 AM |
| Kawasaki FE-350 11.5hp 4 stroke engine | wings3630 | Landscaping & Lawn Care | 2 | 08-05-2008 07:08 AM |
| Engine Slowly Loses Power and Dies While Driving | slickshift | Automotive Repairs | 16 | 01-15-2007 12:34 PM |
