Does Anyone Know These Ants? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 04-25-2014, 09:55 PM   #1
sz8
Does anyone know these ants?
As shown in the pic:
http://i27.photobucket.com/albums/c200/shanzhu/001.jpg
These ants are slightly larger than fire ants in Texas. They look
red on upper body and black on lower body. I have been
seeing these ants around my house (north of Dallas) for many
years. Unlike fire ants, they do not bite/sting.
I have used many types of ants killing granules, sprays and baits and
I failed to eradicate them. They will die with spray but will come back.
From what I can see, they are not attracted by the Terro liquid baits
and a few other solid baits.
They do not have mounts on the ground. I tried to trace them to see
where they go and they seem to vanish either in the ground with
a lot of tree leaves or between house bricks on the other end.
I also found that they like to stay in rotten wood and they do not
normally carry/move stuff with them.
Anyone knows what type of the ants there are? How to completely
remove them?
Thanks,
SZ
sz8 is offline   Reply With Quote
Old 04-25-2014, 10:02 PM   #2
Rewards Points: 780
Sorry I don't know what kind they are, but get some Diatomaceous Earth and sprinkle it on the ground where you see them. I've used it on ants and it worked well.
http://www.richsoil.com/diatomaceous-earth.jsp
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
r0ckstarr (05-01-2014)
Old 04-26-2014, 01:27 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Nope....never met them before. But then again, I'm not that good with faces.
The Following User Says Thank You to ddawg16 For This Useful Post:
joecaption (04-26-2014)
Old 04-26-2014, 09:39 AM   #4
sz8
Thanks for the replay.But
is that product more effective than the ant granules sold in
big box store? It looks like it is safer but I want something
really effective. I suspect without effective bait, the queen
can be not killed. I used bait method for many other types
of ants effectively but not this one. Still searching.
Thanks,
Old 05-13-2014, 07:32 PM   #5
Rewards Points: 32
I'm no expert but I've have been dealing with ants lately. Those look like Florida Carpenter Ants which are also called "red and black" carpenter ants.
shark_bait is offline   Reply With Quote
Old 05-13-2014, 09:05 PM   #6
mtm
Rewards Points: 18
Being that your in Texas, and you have never seen them before. I would guess Raspberry Ants aka crazy ants.
but its a guess..
mtm is offline   Reply With Quote
Old 05-13-2014, 10:13 PM   #7
Rewards Points: 528
Does that DE only kill the ones in contact with it or is it taken back to the mound/queen?
hidden1 is offline   Reply With Quote
Old 05-14-2014, 02:09 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
looks like Bill and his twin,Harry
Old 05-15-2014, 07:39 PM   #9
Rewards Points: 350
Originally Posted by sz8 View Post
I also found that they like to stay in rotten wood and they do not normally carry/move stuff with them.
remove them?
Thanks,
SZ
I agree, some type of carpenter ant native to your location. They look like wood eaters. I wouldn't want them around my house.
Take one to your local county extension agrcultural department or pest control exterminator for identification. They should be able to give you the best advice on what they are and how to get rid of them. Just a suggestion.
jmon is online now   Reply With Quote
Old 05-25-2014, 09:04 AM   #10
Rewards Points: 16
Looks like an acrobat ant to me. I've used Delta Dust successfully before on them indoors and out.
Easypick is offline   Reply With Quote
Old 05-25-2014, 07:14 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I can tell you what not to try.
DON'T use an oxy-acetylene torch to try to burn them out...I burned down an entire section of a park at Grapevine Lake using a torch to rid myself of ants one time. Helluva fire it was too!!!
XXX
Old 07-18-2014, 02:40 PM   #12
They seem to be carpenter ants, SZ. I would try to take care of this issue as soon as possible.
PioneerPest is offline   Reply With Quote
Old 07-18-2014, 09:42 PM   #13
Rewards Points: 960
Yes, the one on the bottom is named Freddy. Sorry, I don't know the one on the top.
cleveman is offline   Reply With Quote
Old 08-03-2014, 04:29 PM   #14
Collins Combustion
weracemo's Avatar
I had an Ant problem. They started showing up in my kitchen. I watched videos about borax and found Terro was very popular. Got three types of Terro at Home Depot and looked at the label when I got home. Guess Terro likes borax as well since it is the active ingredient.
My Ant problem was solved in three days and visibly gone in five hours. I found the trail outside and placed a pop bottle cap of the liquid in it beside the trail then poured the liquid all around the trail and on top of the ants. They kept walking past the Terro until the scouts found it then wham it was like liquid crack to those ants.. they don't die instantly but take it back to the nest and the whole nest dies... It really worked good so I used the rest of my purchase on the ant hills all around my yard. Have not seen an Ant since...
weracemo is offline   Reply With Quote
The Following User Says Thank You to weracemo For This Useful Post:
r0ckstarr (08-03-2014)
Ants Ants Ants Amitabh Pest Control 14 05-22-2014 07:35 PM
Carpenter Ants - How long to wait for treatment? rchiav Pest Control 9 09-12-2011 12:07 PM
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
Need advice on carpenter ants Antmadness Pest Control 4 08-29-2010 07:55 PM
a few large ants by tennant's front door... what are they? diy'er on LI Pest Control 3 07-18-2009 08:14 PM
