Desperately Need Help With Rodent Problem - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 05-02-2011, 04:56 PM   #1
Unhappy
desperately need help with rodent problem
ARGH! I had a huge post written about my rodent problem and it's gone!
Long story short, pests in my house, think they are rats & mice, possibly squirrels, noises at night, smells bad in house, losing sleep, concerned about health and damage to air ducts, wiring, etc, not enough room in attic to set traps except near access, have seen them in kitchen, tried cage traps, glue traps, snap traps. Best so far is black plastic snap traps for rats (t-rex maybe? can look when I am at home tonight), caught 2 mice in kitchen, catching 1 at a time in kitchen not good enough.
Ongoing problem and desperate for solution. After I figure out how to get rid of them and keep them out, what do I do about damages, how do I get fresh air to breath!?
GrandPixel is offline   Reply With Quote
Old 05-02-2011, 05:25 PM   #2
the Musigician
DangerMouse's Avatar
I hate it when I do that too.... you hit the alt or ctrl or some darn key that moves the window or closes it, etc.
So far as your mouse problem, more and better traps, seal up the house tighter.
Here's a quick read or two from here: How to make a better mouse trap....for free!
and: Yes Dear, I'll build you a better mousetrap....
*Good luck!*
DM
Old 05-02-2011, 06:01 PM   #3
Learning by Doing
Leah Frances's Avatar
For a real infestation I would contact an exterminator. It is more money than DIY, but you'll save on stress and wasted effort.
You could consider natural controls. Dog, cat, owl......
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-02-2011, 06:55 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Throw a couple snakes in the attic. :D
The Following User Says Thank You to Red Squirrel For This Useful Post:
mustangmike3789 (05-04-2011)
Old 05-02-2011, 07:09 PM   #5
just a tool guy
mickey cassiba's Avatar
Yeah but in a month or two you may have to invest in a mongoose
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 05-02-2011, 07:21 PM   #6
the Musigician
....and then it'd be a real bear to get a real bear up there to get the mongoose.....
DM
Old 05-04-2011, 09:47 AM   #7
pest control operator
trapping is not that reliable when trying to solve a serious rodent problem. After the problem is minimized, then keep traps set with fresh bait.
Sometimes people don't want to use rodenticides, but for a serious problem, I only do that. Buy the bait that is in compressed blocks, meal. The pellets are ok if they eat it; I have experienced that rodents sometimes stash the pellets somewhere else.
Keep bait away from dogs especially. Cats rarely bother bait, but dogs are chewers. Any brand at the big box stores, local hardware and feed-supply stores will work.
PAbugman is offline   Reply With Quote
Old 05-04-2011, 12:28 PM   #8
All Things Design
When I first moved into my home 10+ years ago I realized I had a mouse problem in the basement when I caught 14 field mice in a 2 week span, damn rodents, they were apparently living on top of the drop ceiling in the basement. I have since installed a sheetrock ceiling so if any more get in they won't have the span of the entire ceiling to roam around. They were entering underneath the siding above a basement window, I actually managed to run over to the window and catch a chubby one trying to get in but was having trouble.
I used nothing but snap traps, every single one worked perfectly except for one when it only caught the shoulder of a mouse who was running in circles trying to get out. I drowned him in a 5 gal bucket of water.
I would buy several snap traps and start getting rid of them right away. Some snap traps are better than others, I managed to find a brand that worked very well. I called in an exterminator but all they did was put down poisoned bait, I have no idea how well that worked. I prefer seeing them dead so I know how many I catch/kill.
Rock8Reno is offline   Reply With Quote
The Following User Says Thank You to Rock8Reno For This Useful Post:
DangerMouse (05-04-2011)
Old 05-04-2011, 06:07 PM   #9
I too had a rodent problem in my house.Trapping them was never the issue it was keeping them out!!!!I live two houses from a grain elevator and once the hard freezing temps of winter came so did they,I'd swear I'd see them marching!!!The best solution for me and what worked was stuffing every nook and cranny with steel wool and caulking!!Sure they'll nibble and will chew at the caulking but the minute those chompers hit the steel that was it
Jasonlongor1 is offline   Reply With Quote
Old 05-05-2011, 03:24 PM   #10
I agree with PAbugman. You'll never get them all with traps or least not as fast as they can breed. Set out some delicious poison. I believe (bugman may correct me) that the pellets dehydrate the rodent as they die, so they search for water and don't stink as they decompose. I used little packets of pellets and as they ate them, I replaced them, ensuring they had a steady meal of poison.
creeper is offline   Reply With Quote
Old 05-08-2011, 05:34 PM   #11
Too Short? Cut it Again!
I've had many of just about every kind of critter you can imagine in houses I have worked on. Are we talking mice, squirrels, possums or raccoons in in this instance? If you are hearing the pitter patter of little feet enough to keep you awake at night, I am guessing you have something bigger than mice living with you.
I would call an exterminator for an assessment before you waste to much DIY money and energy with poor results. You has a DIYer can plan to block the entrances and exit of the rodents once found though.
Not sure what died to make your place smell. Again, I doubt a mouse or two would be that noticeable.
Tags
mice , rats , rodents , squirrels
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
