Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 05-16-2012, 09:30 AM   #1
Crawlspace & Termites
I recently discovered termites; fortunately, not much damage. Armed w/benefit of advice here, had a local exterminator come and treat with Termidor, all is good.
My next project was addressing my poorly insulated, unconditioned crawlspace. I had contractors in to sprayfoam insulate and they read my order wrong: they sprayfoam insulated the cement walls. They completed the work properly, and went back and sprayfoamed the rim roists and ceiling joists, so that part is good.
Bad part? Now closed cell SPF goes all the way from the ground to the ceiling. I have no voids in the coverage to inspect for termites and I know those buggers will eat through the SPF also to get to the house.
**** So, question is: Do I cut out SPF at the bottom or the top, near the rim joists, to provide exposed cement for termite inspections? And honestly, the more I think about it, the more I want the SPF contractors to come back and do that work...
TIA for your help....
dortress is offline   Reply With Quote
Old 05-16-2012, 04:33 PM   #2
Moderator
I haven't research that topic very much, may want to do more, #7; http://www.energysavers.gov/your_hom.../mytopic=11480
Gary
Clothes taking longer to dry?
Dirt floor conditioned crawlspace with horizontal 80% furnace, and mold remediation WillK General Discussion 0 04-29-2012 11:20 PM
Ventilated or Unventilated Crawlspace? Thunder Chicken Building & Construction 12 01-09-2012 10:08 PM
Crawlspace mold repair questions jeep4dog General Discussion 2 11-04-2011 08:03 AM
Crawlspace Moisture - Serious Problem PaoloM General Discussion 11 12-15-2009 02:35 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
