Copper Mesh Alternatives For Filling Mouse Holes? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Like Tree1Likes
  • 1 Post By Studly
Old 11-09-2016, 02:31 PM   #1
Rewards Points: 229
copper mesh alternatives for filling mouse holes?
I know copper mesh is ideal for stuffing exterior holes/gaps on a house so mice don't get in because it doesn't rust. But no place around me sells it, and I plan to also fill holes with expansion foam.
Wouldn't it work to use regular hardware cloth or steel wool to fill holes as long as I have foam surrounding and mixed in with it? Then it wouldn't rust, right?
Or is there any source of copper mesh that is usually available locally and easy to find in regular chain stores? I thought I once read that there is some kind of copper scouring pad material or "copper wool" that you can sometimes find in the kitchen supplies section of a store ... has anyone heard of that, and if so, what stores sell it?
Studly is offline   Reply With Quote
Old 11-09-2016, 02:51 PM   #2
Rewards Points: 1,256
Re: copper mesh alternatives for filling mouse holes?
The price of copper has probably put the brakes on the manufacturer of items we once found useful. Your idea of hardware cloth, being radially available in different mesh sizes and ease of working with is a good idea in my opinion.
Rust, I've used hardware cloth on gutter down spouts as filters for years without rust. Being it's galvanized and where it is cut exposing the mild steel wire ends would be the only rust areas I would think but I haven't found that a problem.
Old 11-09-2016, 03:18 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,198
Why not steel or aluminum mesh?
Hardware stores/home centers sell screen material or a screen repair kits that would work for a mouse hole.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 11-09-2016, 04:21 PM   #4
Rewards Points: 3,908
Just a thought. Physically blocking their path is important, but eliminating any sense of heat or smell of food could also improve the process. It is food or a warm place that got them started and if they know it is behind whatever you put up, they will search for another way.
Example, I boarded up one of those gable end soffit triangles that I had left open too long and a gray squirrel had taken up residence, After i closed it, he attacked the boards ripping off chunks of wood. Strangely, he also attacked the other triangle on the other side of the gable. Smart enough to know both paths would lead him to what was his home.
Bud
Bud9051 is offline   Reply With Quote
Old 11-09-2016, 04:33 PM   #5
Rewards Points: 229
I've read comments from others that they can chew right threw screen window material. I think a stiffer/sturdier material is needed.
Old 11-09-2016, 04:35 PM   #6
Rewards Points: 229
That's good to know, that hardware cloth is pretty resistant to rust. Is most hardware cloth galvanized, or only certain kinds?
Old 11-09-2016, 05:16 PM   #7
I've never seen any that wasn't galvanized but I suppose I've missed a few things in life.
Old 11-09-2016, 10:22 PM   #8
Rewards Points: 2,052
I have bought Copper screen and sheet, from a sign shop before. It was kind of expensive but they use it to make commercial signs, and have some "scrap" leftover cuts that they can't use, but still hang on to , because of recycling.
Try a sign maker in your area, you might get a deal.
ED
de-nagorg is online now   Reply With Quote
Old 11-13-2016, 04:49 PM   #9
Rewards Points: 454
1) copper prices are not what they were in 2008-2009. If they stopped making copper mesh products its not because copper is expensive anymore. China is not building like mad anymore.
2) Aluminum mesh/screening as mentioned above is a good alternative- Ive used it and it doesnt "rust"/oxidize like steel.
3) Steel wool WILL rust pretty soon after stuffing the hole.
4) try brass wool- painters use it to smooth down roughened 1st coat varnish/polyurethane on contoured/profiled interior casings/trim. (Slivers of brasss "hooked" on small wood splinters will not leave a rust stain if left undetected on the trim in the future. )
papereater is offline   Reply With Quote
Old 11-13-2016, 06:06 PM   #10
Rewards Points: 229
Thanks for the tips everyone! After posting the original message, I've done some more reading on different forums and it seems like the copper wool stuff you can buy at Walmart and other places is not 100% copper. I ended up finding a 100 ft roll of the copper mesh Stuf-fit (that the pest control people use and recommend) on ebay for about $33 ... so that should last me many years and wasn't too expensive.
I appreciate the tips though!
de-nagorg likes this.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
