Chipmunks...They Are Everywhere - Pest Control - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 01-23-2009, 07:58 AM   #16
47_47's Avatar
Rewards Points: 58
Originally Posted by Scuba_Dave View Post
Is that the right picture?
They stored 3 tractors?
Or is it what is in the bucket that they stored?
Originally Posted by Leah Frances View Post
I want to know if 47_47 likes his Kubota. DH and I are talking about getting one.
I do like my BX24. We've moved quite a bit of dirt (45 yards), stone (30 ton), block for retaining walls, 8' tall Arborvites, removed stumps, installed drain pipe... It is compact, can get into tight spots, well engineered, my wife is very comfortable operating the tractor, but best of all it beats using a shovel and wheel barrow.
Negatives are the capacity (750 lbs, 4' bucket), digging depth of backhoe and slow cycle rates.
Initially this is a little small for my projects, but in a few years it will be the right size (and no Scuba_Dave, it is not going to grow). I got it in April of 2007, have ~180 hours and have not had any problems.
You could check out http://www.tractorbynet.com/forums/
47_47 is offline   Reply With Quote
Old 01-23-2009, 10:15 AM   #17
Rewards Points: 1,088
I bought the harbor freight special small rodent trap for $9.99 during the summer of last year and in about 3 months, caught the following:
Female Chipmunks - 15
Male Chipmunks - 3
Rat - 1
Cardinal - 5
Squirrel - 2
I ended up drowning the chipmunks and the rat. I released the others, as squirrels actually perform a service, per se, by cleaning up the pear buds from my tree, and don't dig holes.
I used sunflower seeds (shelled and roasted) as bait.
http://www.harborfreight.com/cpi/cta...emnumber=94397
handy man88 is offline   Reply With Quote
Old 01-23-2009, 03:55 PM   #18
Rewards Points: 77
Death pool is cheaper!! $2 for the bag of seeds. No need to handle any live critters, they are dead & drowned in the bottom of bucket when you get home from work. All you have to do is dump the contents into open hole in your garden. I put it out one morning & in no more than 10min I had one trying to tread water. They take about 5 or 10min until they give up.
dbldee20 is offline   Reply With Quote
Old 01-29-2009, 11:12 AM   #19
Remodeling Contractor
Originally Posted by dbldee20 View Post
Fill a 5 gal bucket 2/3 with water. Cover surface of water with 1" of sunflower seeds(they float) Set a plank of wood 1X6" overlapping the rim of bucket by 5" or so from the ground. Bait the plank with seeds & a small amount of peanut butter. Drop a small spoonful of PB on top of seeds in bucket just out of their reach.
I had tried to rid my yard of these striped rats for years with no success. THIS WORKS EXTREMELY WELL. I drowned 25 in a about 7 days. When I remodeled my kitchen I found they had been nesting over winters in ceiling above my plaster. They got in under cedar siding. I have 2 Pin Oaks in my yard, they love acorns & will nest in your house.
You will know you got one when the PB is disturbed on surface of seeds. They sink to the bottom after drowning. Dig a hole in ground & pour contents into it. I have dumped out as many as 5 at a time. They LOVE peanut butter!! Make sure they have to jump from the plank(Diving board) to reach the seeds/PB in bucket. If you have squirells, you may have to try to keep them off the bucket. They love the seeds as well but will not go in, they will sit on the rim and eat seeds. Make sure water isn't too close to surface, the chipmunks will hang over rim to get the PB/seeds. They WILL jump for it if they cant reach it. You can just add fresh seed/PB to surface instead of dumping each time.
As of end of last fall I had absolutely no more chipmunks. If you see a few in your yard you have many more than that. I tried poison, traps, bait etc. This works, be patient.
I use this method for years. Catch about 6 every night until they are gone. The raccoons and fox loves to tip over the bucket at night to eat the dead chipmunks. My wife hates to see them doggy paddling for hours, but they have to go. healthy plants just fall over after they have eaten the roots clean through.
Old 01-29-2009, 11:05 PM   #20
Tired & Dirty
Rewards Points: 83
any chance of a photo of the bucket setup? can't quite picture it?
evapman is offline   Reply With Quote
Old 01-30-2009, 05:38 AM   #21
Use any bucket, I use a 5 gallon drywall compound bucket. Fill about 2/3 with water. Float about a handful of sunflower seeds on the water. Now make a ramp to the edge. I use a 3" wide X 4' piece of plywood. Sprinkle some seeds up the blank. At first they will eat those seeds. But soon they dive in after the ones in the tank. They try to hang on the sides, so this is why you need to not overfill the bucket.
Old 02-12-2009, 05:09 PM   #22
I have a HUGE Chipmunk problem. We moved in to our house a couple years ago. At first, we thought they were cute, harmless, etc, etc.. but, now Ive come to the conclusion we have got to get rid of them..
They have found away to tunnel under our entryway into the garage/bsmt. They come into the house..Thats where I have to draw the line. They have dozens of holes in the front yard. I'll cover them with rocks or bricks..They just dig around them. They are impossible to discourage.
I also happened to get mice in my garage this year. Likely because they use the Chipmunk tunneling. I caught 4 mice with traps, and also placed some rat poison in the garage, just in case a chipmunk, or rat was living in there.
Nothing touched the poison or traps for a month. Now all of the sudden the posion pellets have been chewed on, and one pellet is actually missing (theyre pretty big). Theres no way a mouse could do that damage. Whats funny is the peanut butter mouse traps are untouched..Soem type of rat, or probably chipmunk.
Anyways..I really hate to posion anything..but I dont know what else to do. I could do the sunflower bucket thing..but I really dont want anything to suffer unnecessarily (i.e., I dont want to hear it paddling around the bucket for hours).
I bought some special foam sealer Im going to use to try to seal any gaps where I beleive the critters are coming in. I know they can chew threw it..but, theres really no other option. Im not crawling under the stairs to methodically fill gaps with something more solid just to have a chipmunk fall in my face. Im caustrophobic as it is..
Ive used mothballs before..They do seem to work with mice..but of course, they will stink up the area you place them in.. Doubt it will work with chipmunks.
Maybe I can try to put several mothballs in every single hole. Maybe that will irritate them enough to move to the neighbors house..
I should use decorative gravel around the entry way too, instead of mulch. Then it will be inpenetrable.
Tommy2 is offline   Reply With Quote
Old 02-13-2009, 10:46 AM   #23
Rewards Points: 562
Find a five gallon jug. Fill with water. turn jug over on top of burrow. They will pop up inside jug. From there its up to you if you want to teach them to endurance swim,,,or relocate them.
We first learned we could water drown them out at a one room country school. We hand pumped all the water into coal buckets. Caught the little boogers. We had a sweeping compound can almost full on bottom before the teacher caught us. We had to let them all go!!! This was many a moon ago. Around here they are called striped ground squirrels.
I read,and never tried it myself, BUT someone said bubblegum spread on or near there tunnels. they cant digest that and get stuck up.
Another try might be like mice and rats,,,try a pan of coke a cola. mice and rats cant burp. doubt ground squirrels can either,,if that doesnt work,,stir in some 'golden maldrin' fly bait. it works VERY well for raccoons in the sweet corn patch too. If they get more than 10 feet before they go toes up,,,mix in a bit more fly bait. (Dry weather, and ONLY source of moisture/water improves odds)
4just1don is offline   Reply With Quote
The Following User Says Thank You to 4just1don For This Useful Post:
yeldarb (08-27-2011)
Old 02-17-2009, 07:17 AM   #24
Rewards Points: 77
These rodents will tunnel along your foundation & nest in your home over winter. I found a pretty large nest above my plaster ceiling when i remodeled my kitchen. It sounds like you have a big problem. They will search for food in your home & destroy anything to get at it. If they are in your garage they will soon be in your home if it is connected. THEY ARE RODENTS. They will also destroy numerous plants by eating the roots.
The bucket works. It's so easy & cheap to set up. There is no need to watch them drown. I would set it up before i left for work. You can tell you caught one if the seeds on surface are wet, i use about an inch of seed to cover surface of water. You will never have to handle them, I just dig a hole in my garden & dump the contents into it. They sink to the bottom after drowning. I got rid of at least 20-25 in 7 days of setting it up. By the end of last fall I had no more chipmunks. Move the bucket around your house where ever you see activity. They cannot resist peanut butter. I usually drop a small spoonful on top of the seeds, just out of their reach. I would also smear a tiny bit on the plank leading up to the rim. You want to overlap the rim of the bucket with the plank of wood. I used to think they were cute too, until i found they were nesting in my home. Personally I wont tolerate rodents in my home. They multiply quickly.
Old 02-17-2009, 07:33 AM   #25
Rewards Points: 77
You may want to try a "have a heart" trap. Im not sure you can find a trap for critters as small as chipmunks. I dumped as many as 5 or 6 at a time from my death pool into ground. They are no different than mice IMO. I wouldn't want mice in my home. I tried numerous types of poison with no luck. I didn't want a neighbors cat to eat the poison so i tried the bucket. Keep in mind if you poison them they may die behind your walls, which will not smell very nice as they start to decay. They only other critter that will mess with the death pool are squirrels, but they will not go in, they just sit on the rim and grab the seed. The chipmunks will hang off the rim to get the seed, so make sure the water/seed is far enough below the rim so they have to jump for it.
Old 02-17-2009, 12:07 PM   #26
How would you modify the death bucket for squirrels? Will it work on them?
jkrodger is offline   Reply With Quote
Old 02-17-2009, 12:33 PM   #27
No. The squirrels will sit on the ramp and eat all the seeds. But this leaves them a sitting duck for a shotgun blast.
Old 02-17-2009, 05:03 PM   #28
Rewards Points: 77
maybe a bigger bucket for squirrels? if they can touch the bottom they will probably jump out. you would have to keep seeds/water low enough so they jump in for it. they get pretty comfortable sitting on the rim of a 5gal bucket eating the seeds, so they could easily be shot while feeding. i think squirrels are territorial so i seldom see more than one in my yard.
Old 02-17-2009, 06:24 PM   #29
your lucky. Usually shortly after shooting one, the next one shows up. I get about 6 a day. Squirrels will just sit and eat. No interest in the seeds in the bucket. It is great for moles, voles, chipmunks and mice and rats. That is about it. At night the raccoons or foxes will clean your your kill so you do not even have to bother it. Avoid looking into the chippy's eyes as he slows down those desperate treading. In fact the way you hunt squirrels is to shoot one, remain silent and still and mark on your map where they land and die. Soon another will look into what is all the noise was. Continue until you have a pot fill. Use a flashlight and gather them all up.
Old 08-27-2011, 10:45 AM   #30
Talking
This Works!!!
I've been plagued by chipmunks for quite a while but this year took the cake. Anyhow - I did the bucket, walk the plank trap - I go 2 yesterday/last night. I went to the trap this AM - 2 dead as rock chipmunks!!! I'm thrilled. I've added 3 more traps - my garden is about 1/2 acre - I've got my fingers crossed - buy what a stroke of genius! Thanks a whole bunch!!! Bill
yeldarb is offline   Reply With Quote
Chipmunks or moles? Proulx06 Landscaping & Lawn Care 1 07-09-2007 12:17 PM
