Carpenter Bees - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-28-2016, 02:09 PM   #1
Rewards Points: 590
Carpenter bees
I probably start a post about these damn things this time every year but they always come back. What I want to do this year is put some powder in the gap that they use to get to the wood on my house and then cover that gap so it can't be used anymore. There must be something for this purpose. I will attach a picture so you know what I'm talking about.
It's at the roof line between the aluminum covered soffit and the vinyl siding. It's the only access they have so dusting to kill what ever bees may be in there nesting and blocking that access point I think will solve my problem for good.
nikeman is offline   Reply With Quote
Old 03-28-2016, 02:11 PM   #2
Rewards Points: 590
Re: Carpenter bees
If you look at the top right corner you can see the yellow crap they push out as they drill in I guess. It's always across that gap and around my upstairs windows.
Old 03-28-2016, 02:29 PM   #3
Rewards Points: 258
Re: Carpenter bees
you can spray in some boric acid, then use foam pipe insulation to close in the gap, the insulation is a grey brown color so it will blend nicely..if you need to cut the insulation into strips to fit and then push it in for a tight fit..
woodchopper65 is offline   Reply With Quote
Old 03-28-2016, 02:43 PM   #4
Rewards Points: 590
Re: Carpenter bees
Is boric acid a liquid or powder? My pest guy used a powder a couple years ago and it knocked down the population a good deal but they regenerated this year.
Old 03-28-2016, 04:12 PM   #5
Rewards Points: 258
Re: Carpenter bees
you can get iit in a fine powder or granular for putting on the ground, kills everything it comes in contact with, insect wise, safe for warm blooded pets and people..
Old 03-28-2016, 04:27 PM   #6
DIY staff
Rewards Points: 7,174
Re: Carpenter bees
I have found Sevin dust to be effective against yellow jackets--it might work well with the carpenter bees--
Last fall I made a 20 foot long powder blaster to kill off a huge infestation behind a facia---
All junk from the bed of my truck--
Empty plastic oil bottle
20 feet of 1/2" PVC pipe--
Fill the bottle with the powdered Sevin (about 1/2 to 2/3 full)
stick the pipe into the bottle an inch or two---tape it good with black electrical tape
poke a hole into the shoulder of the oil jug big enough for the tip of your air blow gun
tape that in--tape the air hose to the pipe--you are done!
That blasted the powder out in about a minute---safe distance away from the angry yellow jackets.
Yodaman (03-28-2016)
Old 03-28-2016, 05:43 PM   #7
Rewards Points: 1,286
Re: Carpenter bees
I've read a lot about the fact we're wiping out pollinating bees. I didn't know that Carpenter bees do that also.
http://www.beyondpesticides.org/asse...%20CONTROL.pdf
Boric acid does have some hazards. Look up the SDS.
( I didn't change the type!)
Nik333 is online now   Reply With Quote
The Following 2 Users Say Thank You to Nik333 For This Useful Post:
oh'mike (03-28-2016), Yodaman (03-28-2016)
Old 03-30-2016, 04:41 PM   #8
Rewards Points: 18
Re: Carpenter bees
I have dealt with this problem. I called exterminators twice and they got rid of them, but they came back a year later. Got tired of paying them every year. Found it much cheaper to do it myself.
Best powder to use Drione dust, and the Dustick dusting tool. You don't need the Dustick tool if you can get up there without it, and are comfortable being close to the bees. You just need any duster/puffer.
Drione dust is the shiznit. Takes care of pretty much any insect you can think of. Totally takes care of Carpenter bees.
Oh...just a small word of advice...powder needs to stay loose, so you dump 5-6 pennies in the duster to keep the powder puffing nicely.
shakham is offline   Reply With Quote
Old 03-30-2016, 05:01 PM   #9
Rewards Points: 13,732
Re: Carpenter bees
Main reason your having this issue is who ever built that house messed up when installing the siding and installed the fashia over the siding instead using J molding.
Water over the dam now.
This is what I'd suggest using.
http://www.domyownpestcontrol.com/bo...sEwaAjkG8P8HAQ
No way would I suggest trying to fill those gaps with any type of foam Like Great Stuff, it will just come running out and make a mess all over the siding, coil stock and the deck below.
No way is trying to stand on a ladder that high up and trying to use a puffer to trying to get it into those small gaps going to work.
Just going to end up with white powder all over the siding.
Old 03-31-2016, 07:08 AM   #10
Rewards Points: 590
Re: Carpenter bees
Joe. If I spray that stuff on the gaps how long will it last and will it make its way to any bees inside the gap? I have a 2 gallon round up sprayer that I'll rinse out if this will work
Old 03-31-2016, 07:29 AM   #11
Rewards Points: 258
Re: Carpenter bees
that boracare is made out of borax, and at $75.00 a gallon its a rip off, you can buy a 5 pound box of borax for a few $$ and google how to make it into borate, very easy, there are many recipies that work great, its an old ship builders secret to treat the wood for both anti rot and insects... http://homeguides.sfgate.com/borax-c...-biocides.aspx
here are 2 links..http://homeguides.sfgate.com/borax-c...sts-77542.html
Old 03-31-2016, 07:47 AM   #12
Rewards Points: 590
Re: Carpenter bees
I also want to stress that I can not get to or even see the actual holes. They squeeze between the trim board and siding and dissappear behind it. I have put my fingers up in there and can't get past the 1x board and had bees climb out beside my hand and fly away
Old 03-31-2016, 09:52 AM   #13
Rewards Points: 18
Re: Carpenter bees
I used a Dustick from the ground, and puffed up into the eaves. It's pretty easy as you basically stick it in the gap and puff away. You get a blast of dust, and it basically coats everything inside. Any dust on the siding itself washes away next time it rains. The powder stays there really well and you can even see the bees trying to go back up there having trouble. Few days later they are all gone.
Only thing was it is tough handling the tool from far away.
The exterminator used a similar tool, but his was hooked up to a compressor to make it easier. I guess if you're doing it all day, you need it to be less taxing.
BTW...I am in no way affiliated with any product I'm using. This is just me dealing with the issue from experience.
However...
If someone has a more permanent solution, aka some piece of ridge type molding, j-channel, or whatever. I'm all ears!
Old 03-31-2016, 10:47 AM   #14
Rewards Points: 459
Re: Carpenter bees
My wife came up with an amazingly simple solution to a Carpenter Bee problem we had in my garage a while back:
She left a small radio on very low pointed at the area that they were nesting. It blew my mind that within a day, they packed up and left. After a week, they quit buzzing around the area altogether. They come back every spring until we turn the radio on for a week.
I know, I know, sounds like a joke, but it's not. Any chance you can run a little radio near that area for a week or so?
Nick DIY is offline   Reply With Quote
The Following 2 Users Say Thank You to Nick DIY For This Useful Post:
Nik333 (04-01-2016), Phases (04-25-2016)
Old 03-31-2016, 08:48 PM   #15
Re: Carpenter bees
Give Lamb exterminating a call 804-592-9531, Dependable is closer but I do not trust them.
Ask for Chris and tell them Joe Robichaud said to call and tell them you want Chris to show up and look this over.
You've been dealing with this long enough
expanding foam to stop carpenter bees nikeman Pest Control 10 05-24-2014 10:17 AM
mesh for carpenter bees njitgrad Pest Control 3 06-15-2012 04:02 PM
Carpenter bees will infest pressure treated wood downunder Pest Control 0 05-08-2011 11:49 AM
