Carpenter Bee Problem - Pest Control - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 06-27-2010, 06:16 PM   #16
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
If the above doesn't work, call a bee keeper. I had a BIG hive under my shed last year that cost me 1/4 of the floor. I got swarmed a couple of times, but no stingers. I'm one of the most unlucky people in the world too. If they do have stingers they probably won't use them.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 04-10-2011, 09:17 PM   #17
I don't think this is an "approved" method, but it's just what I have done.
the aerosol carburetor cleaner that you buy at car parts stores works amazingly well on ANY insect. It kills nearly instantly. Must be some sort of chemical that attacks their nervous system. It will drop a bumble bee or carpenter bee right out of the air. The small spray tubes work well for spraying inside holes that they have bored. When you see one go in a hole, just spray some inside and within a few seconds, they normall fall out to the ground and die.
Engloid is offline   Reply With Quote
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 08:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 09:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
