Carpenter Ants - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 05-20-2010, 09:44 AM   #1
Rewards Points: 152
Carpenter Ants
I know there are a few topics on this asking how to find the nest, but that is not my question.
How do I know if I found the nest? I found a ton of them with eggs and killed them all. I am assuming that I found the nest since I saw eggs. Should I be worried about a possible other nest in the area, or do they typically all usually work out of one?
Also, do the ants stay away from treated wood? I removed all of the moist corroded wood and replaced it with treated wood. I am hoping that this helps keep them away.
Branden is offline   Reply With Quote
Old 05-20-2010, 10:08 AM   #2
There can be more then one nest
Carpenter ants do not eat the wood, they merely carve it up for a home
They tend to stay away from PT wood
Make sure you correct whatever was causing the wood to be moist
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Branden (05-20-2010)
Old 05-20-2010, 10:13 AM   #3
Rewards Points: 152
Thanks.
Correcting what was making the wood moist was the first order of business. I'd really like to meet the previous homeowner that pulled the debacle that caused it. I guess I'll be tearing down more insulation tonight to see if they've gotten anywhere else.
carpenter ants... how to find the nest(s)?! diy'er on LI Pest Control 18 08-01-2014 03:20 PM
a few large ants by tennant's front door... what are they? diy'er on LI Pest Control 3 07-18-2009 08:14 PM
Carpenter Ants & Trees Osiris Pest Control 1 08-30-2008 09:51 PM
