-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Carpenter Ants (http://www.diychatroom.com/f51/carpenter-ants-71678/)
Branden 05-20-2010 09:44 AM
Carpenter Ants
I know there are a few topics on this asking how to find the nest, but that is not my question.
How do I know if I found the nest? I found a ton of them with eggs and killed them all. I am assuming that I found the nest since I saw eggs. Should I be worried about a possible other nest in the area, or do they typically all usually work out of one?
Also, do the ants stay away from treated wood? I removed all of the moist corroded wood and replaced it with treated wood. I am hoping that this helps keep them away.
Scuba_Dave 05-20-2010 10:08 AM
There can be more then one nest
Carpenter ants do not eat the wood, they merely carve it up for a home
They tend to stay away from PT wood
Make sure you correct whatever was causing the wood to be moist
Branden 05-20-2010 10:13 AM
Thanks.
Correcting what was making the wood moist was the first order of business. I'd really like to meet the previous homeowner that pulled the debacle that caused it. I guess I'll be tearing down more insulation tonight to see if they've gotten anywhere else.
