-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Carpenter Ants (http://www.diychatroom.com/f51/carpenter-ants-143289/)
JNAPS 05-10-2012 12:14 AM
Carpenter Ants
Hi, I just found Carpenter ants going up my oak tree in the front yard. I followed them across the yard away from the house and into some bushes. Not sure where they're going from there just yet. I'm gonna follow more tomorrow.. My question is, I put out some advance carpenter ant bait, but they're not going for it. I've used this before and they've gone after it, but not this time. Any ideas why? Do they only look for food at certain times?
joecaption 05-14-2012 07:55 PM
Not sure what your point is. If there not eating the home then there not doing any harm.
JNAPS 05-15-2012 10:07 PM
They're getting to close to the house and I don't want to end up infested again. And no, I don't have any leaks or moisture in the house. I had a huge nest in a wall in the living room once and I want to make sure it doesn't happen again anywhere in the house. Thanks!!
jamjr74 05-25-2012 01:16 PM
I have read that carpenter ants will be attracted to proteins and sugars but usually not at the same time. I believe the granular bait is a protein and they may be looking for a sugar base instead. The gel baits like DuPont advion work well and are sugar based.
JNAPS 05-26-2012 02:30 AM
Thanks for the info. I've tried both and they don't go for either. :(
PAbugman 05-26-2012 10:02 AM
We have no luck with bait for carpenter ants. Occasionally they will go for gels/liquids voraciously but thatís not good enough. We like and are successful with a fipronil based product on the exterior and Phantom inside.
jamjr74 05-26-2012 10:19 AM
Try DuPont advion gel. Works great for me.
benderino 02-22-2016 06:10 PM
Nest high inside the wall with insulation
I used Combat and some seemed to stop and feed while most walked over it. I ordered Termidor and it's on the way.
I cannot find any place these ants are entering or leaving the house so I think they're getting their water somewhere inside. They only use the two small holes that are already there in the wall to dump the sawdust and dead body parts and that's it - they always go right back in.
I was wondering how to deal with the nest that's in the upper wall if I cannot find their source of moisture. I've read about injecting the Termidor into the walls by drilling 1/8" holes along the bottom of the wall in between the studs. I have questions about this:
1) My walls are full of the standard fluffy insulation. Would this still work?
2) Does putting the pesticide near the floor as instructed work for the nest that is 8' up on a 10' high wall?
3) How do I know when it's safe to fill the holes in the walls I've made? Is this a process that may take a full year?
4) I like the idea of such small holes - is there some kind of applicator attachment that fits on the pump setup to get it into such small holes?
Thanks for any insight on this.
Nik333 02-22-2016 06:31 PM
Are you sure they are Carpenter ants? I've read that ants learn what kills their kin & avoid it overtime.
JanetCarlyle 02-25-2016 11:33 PM
Check out for the experts for the identification.
benderino 03-02-2016 10:13 PM
I'm not sure about the OP, but this supports what myself and PABugman posted.
Patrick Crosby 03-21-2016 10:06 AM
Re: Carpenter Ants
Try "Amdro" granulars. Works on most kinds of ants. I use it for Carpenter Ants around my,and my clients homes. Yes Fipronil is great to spray perimeter. I would hire a pro for this . Remember the (label is the law) when it comes to applying pesticide.
Amdro at Home Depot ,Lowes,Ace
razibpaul126 04-26-2016 05:44 AM
Re: Carpenter Ants
Carpenter ants are big ants that live in many areas of the world. They like to build their nests or colonies from dead, damp timber. However, contrary to general opinion, they do not eat wood as termites do. They use wood to build their nests and tunnel through it in their search for new sources of food. This is proved by piles of frass, which is the debris that the carpenter ants have chewed out of typically damp. dead wood.
