Is Bug Spray Harmful To Small Animals? - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 08-09-2009, 04:05 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Is bug spray harmful to small animals?
I used some spider killer (CIL Spider Ban) around the window as there was some spiders and webs, then only thought of it after, the chipmunk always hangs around here. Should I be worried that the fumes will harm it or should he be ok? I did not spray to the point that it's leaking all over, but it's slightly wet.
What is a more natural way to take care of spiders and bugs? I hear sunlight works well and is unharmful to animals, is this true?
Old 08-09-2009, 08:26 PM   #2
long island, NY
well, in my opinion, as long as they're outside, spiders are totally fine. As a biochemist/medical researcher, I must warn you that no pesticide is "safe" dispite what they advertize. Most pesticides have molecular structures that are similar new nerve gas :-o. They kill by paralyzing the animal and stopping them from breathing. Companies get away with saying they're harmless becuase they stick a little methyl group onto a known (usually banned) toxin, and declare it to be a "new chemical that is safe". most of the time, it's basically the same thing.. but science must spend years proving that... In the interim, it's still "safe". This ethically-challenged pesticide marketing game has been going on for over 40 years.......
Both bugs and humans have the same proteins that those sprays target. We douse areas with bug sprays in the hopes that the small bugs get such a large dose (proportionately to their size) that it kills them. Obviously, our huge bodies would need more to be killed. It would work wonderfully if repeated small doses doses didn't do any harm.... alas they do.
I write this long-winded post merely to let the other DIY posters know that bug sprays are much more dangerous than the companies let you know. Don't use them indisciminantly.
As for myself, I would only call an exterminator if there was an exceptionally dire situation (ex. carpenter ant or termite infestation). I would never use the canned sprays... since it would be on surfaces my family might touch (floors, walls, windows). In the last 5 years, I only purchased a few "hotels".
hope this helps
diy'er on LI is offline   Reply With Quote
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 09:42 AM
Spray painting wood siding Martshandle Painting 6 03-29-2009 09:50 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 10:38 AM
