A Bird In My Basement! - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 01-24-2012, 11:37 AM   #1
A bird in my basement!
Somehow a bird got into my basement. There is 6 windows that are always closed, a dryer vent that is always hooked up to the dryer, an old coal shoot that is sealed, and a furnace and chimney. There are no exterior doors into the basement.
I'm assuming that the bird came down the chimney and through the furnace, because there is no other way I can think of that it could have gotten in there. The way the furnace is made and hooked up to the chimney, it doesn't seem impossible, but pretty improbable.
The bird is now out and trying to fly into someone else's basement, but after the original shock of seeing a bird in the basement, I went to get a sheet to catch the bird with last night and I spent 20 mins walking around in the basement and couldn't find any sign of the bird. Today, he was back.
Is it possible that it "knows" how to come and go as it pleases? How do I make sure this doesn't happen again?
harding13 is offline   Reply With Quote
Old 01-24-2012, 12:21 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Get a cat.
titanoman is offline   Reply With Quote
Old 01-24-2012, 12:54 PM   #3
pest control operator
I doubt that it knows how to get in and out. More likely it was there but hidden well when you looked for it. Itís very disorienting for a bird or bat to be inside. Did you look closely at every inch of the dryer vent for holes? Check the flapper on the outside to make sure it closes. Is the furnace operating when needed? If so, there would seem to be too much exhaust gas to accomodate a bird. Otherwise, Iíve seen old style barometric dampers that donít use a flapper but are always open to the basement-Iíve suspected them on occasion for allowing bats to enter. Keep us posted.
PAbugman is offline   Reply With Quote
Old 01-24-2012, 02:11 PM   #4
Rewards Points: 150
I doubt it is a coincidence that the bird is back.
There are definitely birds that will try to come into the house and nest---barn swallows, European starlings, house sparrows, maybe more. I found a nest in my basement and the only way the bird could have come in is through a hole I used in summer to run a drain hose from a dehumidifier. When I plugged that up the bird disappeared.
Keep looking for a hole about 1" in diameter. If you find one plug it up but only if you're sure the bird is outside at the time.
NancyNGA is offline   Reply With Quote
Old 01-25-2012, 11:59 AM   #5
Since I got the bird out, it hasn't shown back up.
The furnace is working fine, but I haven't looked closely at the dryer vent. It's been so long since I installed it, I can't remember if it has a flap either. I will check these things out tonight.
Thanks for the recommendations.
Old 02-01-2012, 03:30 PM   #6
bikerpowell's Avatar
How did you end up getting it out?
bikerpowell is offline   Reply With Quote
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
