Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 05-26-2008, 07:48 PM   #1
Question
Big Ant
I found this ant in my house the other day. It's quite a large ant. Should I be worried? I've only seen this one this big. Found about 3 others roughly half this size all in the past 3 weeks.
onthegojohn is offline   Reply With Quote
Old 05-26-2008, 10:06 PM   #2
Big Ant
looks like a carpenter ant... make sure he's just wandering and is not part of a nest. They burrow into wood so getting rid of them is a must...
slakker is offline   Reply With Quote
Old 05-27-2008, 06:54 AM   #3
Big Ant
This is a good read for knowledge and how to eliminate them.
http://www.domyownpestcontrol.com/ca...l-c-1_177.html
mark942 is offline   Reply With Quote
Old 05-27-2008, 11:13 AM   #4
Big Ant
How do I find out if he's part of a nest or just out wandering?
Old 06-15-2008, 11:11 AM   #5
STG
Big Ant
Where are you located, John?
Here in south Texas, we have lots of problems with carpenter ants. The best way to find out whether or not you have an actual issue is to wait until a couple hours after it gets dark. These guys are mostly nocturnal. Take a flash light and do a very slow and detailed inspection of the outside of your home. If they're there...you'll find them.
I had a battle with these guys earlier this summer.
After doing that close look, I initially thought they were nesting in a tree by my house...as there was a highway of them going up and down the tree. But...on closer inspection, I found they were nesting in my neighbor's deteriorated chimney. The highway seemed to end there and the tree was just a "rest stop."
STG is offline   Reply With Quote
Old 06-15-2008, 10:18 PM   #6
Big Ant
Thanks for the reply STG.
I live in the Pacific Northwest, Northern California to be exact.
I think the threat is over, since we only ever found a total of 5 or 6 solitary big ants (none as big as the one in the pic). And we haven't seen any in a couple of weeks. I will do a nighttime inspection though, as you suggest, and see if i find anything.
Thanks again,
John
Old 06-15-2008, 10:25 PM   #7
STG
Big Ant
Hey, no problem!
Good luck with this. My neighbor's been doing some repair work at his house this weekend...and he found the nest (as suspected) in a piece of trim in his chimney.
Old 07-03-2008, 07:33 PM   #8
Big Ant
Good luck getting rid of them. Carpenter ants can do some particularly nasty damage to your house.
Carpenter Ants
gilligan is offline   Reply With Quote
