Beehive In Attic - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-22-2010, 06:53 PM   #1
transmitterrecieverpntgun
beehive in attic
I have had a bee problem for a few years. Wasps and honeybees bolth. I found a large nest in the attic today. It is about 35deg f. outside. Is it safe to simply crawl up in the attic and remove it and look for more?
beehive in attic-03222010iphone-025.jpg   beehive in attic-03222010iphone-029.jpg
utilitylocator is offline   Reply With Quote
Old 03-22-2010, 06:59 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I doubt that nest is even active. It seems quite large for a nest this early in the season. but I would still watch it for activity before doing anything.
If no activity, it would be safe to remove. I would still proceed with caution though and wait until late in the day after it has cooled down. I would then take a garbage bag and envelope the nest all the way to the roof and break it off into the bag and seal it.
If it is active; all bets are off
It looks like you might be able to shoot it from the outside with some wasp and hornet killer spray. That is where I would start.
The Following User Says Thank You to nap For This Useful Post:
utilitylocator (03-22-2010)
Old 03-22-2010, 07:09 PM   #3
Im trying to get a jump start on the bee problem early. There are no bees yet, and I do believe they return to old nests.
Old 03-22-2010, 07:12 PM   #4
I always spray them 1st unless its in an area thats like 20f
I do not like being stung
Old 03-22-2010, 07:13 PM   #5
hornets will overwinter in a nest so i would spray as advised. no need for that kind of suprise
that looks like a white faced hornet nest
The older I get the better I was
Old 03-22-2010, 07:23 PM   #6
HMMMM.....never heard of it. I realy want the nest(s) gone while its still at the freezing mark.
Old 03-22-2010, 07:27 PM   #7
they are here in va, uaually but not always in trees. they fly real fast in a straight line, you see the white face then they are on you. like yellow jackets they come in droves when disturbed
Old 03-22-2010, 08:10 PM   #8
nap
You talking to me?
nap's Avatar
If you can see their white faces as they are attacking, you are pointing the wrong direction!!
It appears this is also known and the bald faced hornet, which is the term used in my area.
and as we discussed this before, wasps and hornets abandon the nests when winter comes.
from Wiki (the we know everything book)
As winter approaches, the wasps die — except any just-fertilized queens. These hibernate underground or in hollow trees until spring. The nest itself is generally abandoned by winter, and will most likely not be reused. When spring arrives, the young queens emerge and the cycle begins again.
Old 03-22-2010, 08:20 PM   #9
Handyman
Rewards Points: 512
lmao! when I was a kid I would have taken it out for a buck! But seriously, I doubt the bees are active at this time of year.
My first house had the same problem. I found a nest about 8' long between two floor joists. I removed it but they came back. I had to fine mesh all openings which I thought gave them entry. I also sprayed some WD40 on the joists they were attahed to. Worked for a couple of years but I have since sold the house so I don't know if it remedied the problem entirely.
canadaclub is offline   Reply With Quote
Old 03-22-2010, 08:21 PM   #10
Well I just took my soffit apart a few weeks ago & there were still 5 wasps alive that I found & killed
So can you please have the Wiki people come over to my house & walk around the house & tell any remaining wasps they should be dead by now
hmmmm...now that I think of it...it was a big yellow jacket nest I got rid of
Maybe a small wasp nest was there on the wood I took down
Old 03-22-2010, 08:54 PM   #11
Man, I'd have a hard time abandoning a nice dry attic for an old hollow tree if I was planning on taking a long winter nap. Ya know what I mean?!?
Old 03-22-2010, 09:37 PM   #12
Handyman
Rewards Points: 512
lmoa Scuba..I was painting and caulking a house last fall and after taking the phony shutters off, every one had a wasp nest behind them. But it was the top of 2nd story window flashing where the bumble bees were! I was stung 7 times on my face 4 times on my arms and I got paint all over the place while trying to stay secure 30 ft up on a ladder. My 'so called" partner was so busy laughing...may he R.I.P lol
Old 03-22-2010, 10:14 PM   #13
So I think I am going to open up the vent hole to accomodate a larger air vent. I can than reach in through the vent and bag it. I think I should also seal up all the cracks and crevases that bees can use to access the attic as well...
Old 03-23-2010, 08:20 AM   #14
Rewards Points: 1,538
Spray it with bee spray anyway, soak it good. Let it dry. Soak it a second time. This is to kill the queen and anyone else who was hibernating there before you manually remove it.
Old 03-23-2010, 10:16 AM   #15
Please spray first. Its just good practice and getting a face full of angry hornets is not fun so why take the chance?
clb2010 is offline   Reply With Quote
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
