Bats - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 09-22-2011, 01:24 AM   #1
Bats
We live near a river and a neighbor down the block has a huge bat house that can't hold about 500 bats. The problem with this is that we also get bats do to these 2 situations. They get into our attic somehow,( I haven't found out where). What can I do to drive them away? Moth balls? Electronic sonic devices? Or any other suggestions?
Travis_handyman is offline   Reply With Quote
Old 09-22-2011, 07:24 AM   #2
DIY staff
Rewards Points: 7,174
You must find the entrance ----if bats can get in --so can other critters.
Best to get a service in to remove them---it's rare but some bats carry rabies.
Old 09-22-2011, 08:37 AM   #3
Rewards Points: 52
And you're not necessarily looking for what we humans might think of as an entrance. Those guys are very opportunistic; a loose piece of soffit, a piece of vinyl siding that came unhooked, or other such obscure openings are all they need, so sometimes you have to feel your way around the area they are using. Unless you can catch them coming and going, and watch from a distance to identify a general area to begin searching, you are probably best served to get an expert, as Mike suggested.
Old 09-22-2011, 01:21 PM   #4
Rewards Points: 526
You could try putting up a bat house of your own. THey may be less inclined to come into your house, if they have a habitat close by that is more suited to them.
Windows is offline   Reply With Quote
The Following 2 Users Say Thank You to Windows For This Useful Post:
1910NE (09-23-2011), josall (09-22-2011)
Old 09-22-2011, 05:24 PM   #5
pest control operator
You must find out how they are entering/exiting. Stand outside at dusk and watch for bat activity. Go into your attic on a bright sunny day and see if you can find any daylight filtering in. Cover attic windows, if any, to minimize light infiltration thru them. Look for small piles of bat droppings. Often times where chimneys penetrate the attic/roof is an entry. Carpentry and obsessive sealing is required, sometimes a man-lift will be necessary. Putting up a bat house outside is a nice thing to do, but will do nothing as far as your problem goes. Moth balls and sonic devices offer no help. Gather as much info as you can as to their entry/exits at your house; that knowledge will guide you to the type of repairs needed.
PAbugman is offline   Reply With Quote
Old 09-22-2011, 05:35 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You probably can't get rid of them so why not provide for them thereby controlling their whereabouts?
The diy bat-house challenge
Old 09-23-2011, 11:20 AM   #7
Rewards Points: 3,130
While my house was still under construction and the soffits not yet installed, we had 10 or so bats in the attic. That wasn't so bad, except finishing the soffits sealed them in so they started coming into the living spaces. It's amazing how small a crack they can squeeze through. I solved the problem with a .410 shotgun and bird shot (it's a log house so no drywall to worry about).
Old 09-23-2011, 02:01 PM   #8
2nd and 3rd plug for providing a "bat house." As others have mentioned, you will probably never get rid of them all together, and they probably help with the bugs that must also live along that river. Some of the web sites with information on building/installing bat houses also discuss how to insure the bat house is placed in a location that the bats will like. Just reverse that advice to keep them away (and put up a bat house away from your house.)
1910NE is offline   Reply With Quote
Old 10-25-2011, 11:59 AM   #9
Rewards Points: 320
I had about 70 bats in my attic. I could see the hole they were coming in and out of (and the wood was getting a black stain on it on the bottom side and rat poo was all over the ground bellow). I put some screen up making a one way door and they all left and we haven't seen or heard them since. They found there way into another hole else where but I did the same thing there. The pros wanted $2000 to fix the problem. Sadly even with that many bats, we still had a horendous mosquitto problem.
autx790 is offline   Reply With Quote
Bats in my attic - how do I get them out? Greg D Pest Control 15 06-22-2011 07:39 AM
closed cell insulation vs. fiberglass bats ben5048 Roofing/Siding 6 01-15-2011 09:47 PM
Blown in insulation over bats Marc7747 Building & Construction 1 10-11-2010 02:01 PM
Bats in my belfry 4just1don Pest Control 6 05-05-2009 10:30 AM
bats in my roof end vents eagle2x Roofing/Siding 1 08-17-2008 12:40 PM
