-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Attic has alot of droppings (http://www.diychatroom.com/f51/attic-has-alot-droppings-26579/)
wedge22 09-10-2008 12:41 AM
So I went up into the attic at the weekend and there were alot of small black droppinfs up there, I am guessing rats or squirrels. I was helping my mate install a ceiling fan for the bathroom and when we raised the insulation there were alot of droppings underneath. Is there anyway to know if they are coming back for the winter and if so whats the best way to deter them?
dac122 09-10-2008 11:48 AM
If the droppings were the size of mouse droppings like fat grains of rice, they crushed to powder unlike mouse droppings (note: wash hands afterwards), and there are shiny bits in the droppings, you are dealing with bats. The shiny bits are bug wings.
Exclusion and/or removal are your only options for bats.
ocoee 09-12-2008 10:59 PM
If it were bats there would be a very distinct, foul strong and pungent odor that is unmistakable and the droppings would most likely not be under the insulation at the very least there would be piles on top of the insulation and the bats will stay close to their entry exit point
Rat poop is larger than rice and will be pinched at one end and will most likely have hair in it almost like a miniature dog turd but not much longer than it is wide
Mouse droppings are miniature rat droppings
They could well be large roach droppings like from an American or Australian roach
They will be about as big as mouse droppings but will be almost football shaped with rounded ends and ridges lengthwise
They look like a seed used in spices but i can't remember which one
Rat sized droppings that turn to powder when crushed could and most likely would be lizard but I doubt there would be so many
If you live in a rodent prone area in a house that has had rodent issues before and have done nothing to stop them from reentering
They WILL be back, there is no doubt about that
Use 1/4 in hardware cloth and foam and seal every crack and crevice larger than a dime, install door sweeps, seal attic vents with the mesh, seal all eave gaps, AC chase ways, electrical penetrations and ridge vent end plugs if the house has ridge vents
A typical house will take me up to 20 hours to complete and will cost between $800 and $1200 some have been as much as $3900 but that one took over a week
Wendelin 09-22-2008 09:48 PM
Wondered whether you figured out what the droppings were because I just encountered the same problem in my attic while trying to install a ceiling fan?
sssalas 09-24-2008 03:02 PM
Get cats
Get a house cat or two, that stay inside the house and are trained to use the kitty litter box and not in the attic!
dac122 09-24-2008 03:14 PM
Controlling a bat problem with cats is very risky. Bats are common carriers of rabies and can easily infect cats. Most likely you would not know if a cat was infected because the bit marks are so small.
Animals infected with rabies are very unpredictable. There is no cure for rabies if you yourself are infected by a rabid animal and not treated in time.
sssalas 09-24-2008 03:22 PM
As mentioned by a previous poster bat dropping would not be found under the insulation. They hang upside-down and the droppings would fall on top of the isulation. So it's more than likely a rat or mouse problem. Even with mice, it's alaways a good idea to have all animals in the home vaccinated against rabies and other diseases.
Bugzilla 10-05-2008 05:48 PM
Could be squirrels or rats. If they were under the insulation, I would guess rats, because they like to nest in insulation. Place half-a-dozen baited snap traps around your attic and check them daily when you get home from work. Also, inspect for any openings where rodents could be entering.
pest control 10-06-2008 04:38 AM
without seeing the droppings its difficult to ID them as someone said before bat dropping will contain bits of insect difficult to see though without a microscope an easy test is to rub the droppings between your finger a bat dropping will turn to dust a mouse dropping will not mouse droppings are the size on a grain of rice. squirrel droppings are much larger and have a more rounded appearance. hope you get the problem sorted
mirrorball 10-13-2008 02:58 PM
I also have alot of droppings in the attic
Hello all,
I've been hearing some squeaking every so often, so I decided to check out the attic and I found a load of droppings. So this has brought be here to look for some answers. I've kinda assumed it's either bats or rats. With a strong leaning towards bats since I've seen bats fly out from neighboring homes.
Anyways, So this is the first thread I saw that was related so I figure I'll post and see if there are photo references which I can compare my situation to others. I've taken a photo, but it might not be detailed enough. I've read that bat droppings usually pile near the entry way and this was near the venting which I would assume is the most likely entry way. So here it is...
http://www.geocities.com/mflomirrorball/IMG_2661.jpg
Thanks in Advance,
Doug
jogr 10-13-2008 03:07 PM
Originally Posted by mirrorball (Post 171814)
Hello all,
Thanks in Advance,
Doug
Mouse or rat droppings would not be concentrated in one place like that. I think you are right about the bats.
ocoee 10-14-2008 07:36 AM
That looks like bat to me
look up there should be some hanging
Also there will be a lot of dirty smudges at the entry point
Rats are incontinent
They just poop
It would be piled up at feeding stations or where they stop for awhile but it would mostly be along their runways
steve1234 10-14-2008 02:48 PM
so how do you rid the house of bats....the correct way?
I found a big nest of bats in my house during a remodel. I pulled some siding off the house, exposed their hideout, then blasted them with a pellet gun and a full auto air soft gun. Got 12 or so, but a couple escaped from the kill zone. Sealed the house back up, and I haven't seen any since.
Ripping the siding off the house probably isn't the most efficient method, unless the siding was coming off anyway.
dac122 10-14-2008 03:01 PM
Exclusion is the only way to rid yourself of bats. Find where they are getting in, put in a one-way exit, and seal up in a few day. Excessive excrement indoors can be a health hazard.
In some locales bat are protected. Doing what you can to rid yourself of them in the most humane way benefits everyone.
SamA 12-09-2010 01:20 PM
hello
I see that this is an old thread but after hearing noises in the attic and checking it out, i fould lots of droppings. i took pictures and have posted them online and you could view them using this link:
http://smg.photobucket.com/albums/v476/MrWolfboy/Attic/
i have written some comments for some of the pictures.
i am not sure what i am dealing with here
in the picture you could see some holes in the dry wall which seems to me as they have been punched from outside and the drywall was hanging from the skin. but the hole was not through all and there was a sheet right behind it .. so it is not making any sense to me at all.
there is a duct (you could see in the picture) that ends at the wall and there is no opening. however it is obvious that the dry wall around it is moldy and falling apart.
this is a fairly new house -- less than 10 years old.
i would appreciate any help or insight.
thank you
sam
