Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 03-16-2011, 10:54 AM   #1
Chicago, IL
Michael Thomas's Avatar
Assistance with identification
Beam in unheated crawl space in Chicago, pipe is hot water to baseboard system, this material was not present elsewhere. Sorry, do not have better pictures.
What am I looking at?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 03-16-2011, 01:52 PM   #2
Wondering if it is possibly where the apprentice happened to get his first opportunity to actually solder some pipe in the field?
Old 03-16-2011, 02:37 PM   #3
Chicago, IL
Don't see any scorching...
Old 03-16-2011, 10:13 PM   #4
Chicago, IL
No one knows?
Old 03-19-2011, 10:46 AM   #5
pest control operator
It appears to be sticking to the wood as opposed to being loose and easily brushed off (not scraped). Is this so? If so, this would rule out ant frass, but could still be cockroach fecal material, which is sticky. However, my gut feeling is that this is not insect/rodent related, especially since you are not finding evidence elsewhere.
PAbugman is offline   Reply With Quote
Old 03-19-2011, 11:05 AM   #6
nap
You talking to me?
nap's Avatar
In the pic on the left, if you look at about 07:30 about an inch from the pipe, it appears to be a couple droplets of solder (silver). I see similar droplets in a couple other places as well. I suspect that is simply the burns from solder droplets, solder itself, or flux.
that is, unless you know of a bug that poops silver solder looking stuff.
Need assistance determining header specifications rgb71 Building & Construction 1 01-06-2011 06:38 PM
Need assistance installing brazilian cherry stairway BobS0327 Carpentry 8 09-07-2010 11:30 AM
Part Identification tomoni82 Landscaping & Lawn Care 4 07-25-2010 03:36 PM
Snake Identification Giles Off Topic 1 06-05-2010 03:37 PM
Getting Contractor Assistance, Doing Work Myself Sean Building & Construction 4 12-27-2006 07:13 AM
