Ants Through Siding - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 06-02-2013, 01:40 PM   #1
Rewards Points: 208
Ants Through Siding
i saw these black ants, look like carpenter ants, going into these gaps in the siding (marked in red circles below).
what can i use to plug up these gaps?
what can i use to kill to these ants?
Scully is offline   Reply With Quote
Old 06-05-2013, 08:10 PM   #2
Rewards Points: 1,062
Dust in some sevin dust. Then, man, you got a lot of gaps, both between the siding/concrete AND siding and siding trim. Gobs of caulk are needed. But blow in /sprinkle in sevin FIRST!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-05-2013, 09:27 PM   #3
Rewards Points: 12,790
Bet you pull off that siding and there's going to be wood rot behind it.
Siding was not suppost to be within 6" of any grade.
That has to be some of the funnest J molding I've ever seen.
oh'mike (06-08-2013)
Old 06-06-2013, 09:11 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 822
+1 Joe.
Way to close and very easy to conceal termites and other destructive pests in that small a gap.
I have used Boric Acid and sugar with little sugar ants but those buggers look like they need something with a bit more HP.
Old 06-07-2013, 08:14 PM   #5
Seven is good, boric acid works well too, or drione would be even better. Don't get a repellent though, everything I've read about carpenter ants says that. And yeah, if they have a nest back there, it's because of a water problem.
CorkWithAC is offline   Reply With Quote
Old 06-07-2013, 11:14 PM   #6
Rewards Points: 208
what type of caulk should i use?
any idea when this type of siding was put in?
Old 06-08-2013, 07:51 AM   #7
DIY staff
Rewards Points: 7,174
You need to pull off the siding in that area--repair the rot and then flash that lime stone cap in some way to keep water out of your house----
Also pull off the bottom course of siding at the patio slab----you may have serious rot/bugs from that wet installation.
Old 06-11-2013, 07:48 AM   #8
Rewards Points: 2,038
flying ants in bathtub
oops. posted in wrong place.
Startingover is offline   Reply With Quote
Old 07-31-2013, 04:50 PM   #9
Rewards Points: 154
7 dust works well, will kill pretty much anything that crawls. But with carpenter ants you really need to find the nest, which is probably in wood somewhere underneath that siding. And you need to make sure you treat THAT with a strong insecticide. If it can't be found once you pull the siding you'll need to find some other way to locate it and get the dust in there.
eharri3 is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
a few large ants by tennant's front door... what are they? diy'er on LI Pest Control 3 07-18-2009 09:14 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
