-   Pest Control (http://www.diychatroom.com/f51/)
-   -   Ants Through Siding (http://www.diychatroom.com/f51/ants-through-siding-181115/)
Scully 06-02-2013 12:40 PM
Ants Through Siding
i saw these black ants, look like carpenter ants, going into these gaps in the siding (marked in red circles below).
what can i use to plug up these gaps?
what can i use to kill to these ants?
http://img90.imageshack.us/img90/7931/img2076xi.jpg
http://img27.imageshack.us/img27/3844/img2067oa.jpg
http://img90.imageshack.us/img90/4589/img2068er.jpg
http://img832.imageshack.us/img832/5070/img2069iq.jpg
noquacks 06-05-2013 07:10 PM
Dust in some sevin dust. Then, man, you got a lot of gaps, both between the siding/concrete AND siding and siding trim. Gobs of caulk are needed. But blow in /sprinkle in sevin FIRST!
joecaption 06-05-2013 08:27 PM
Bet you pull off that siding and there's going to be wood rot behind it.
Siding was not suppost to be within 6" of any grade.
That has to be some of the funnest J molding I've ever seen.
Windows on Wash 06-06-2013 08:11 PM
+1 Joe.
Way to close and very easy to conceal termites and other destructive pests in that small a gap.
I have used Boric Acid and sugar with little sugar ants but those buggers look like they need something with a bit more HP.
CorkWithAC 06-07-2013 07:14 PM
Seven is good, boric acid works well too, or drione would be even better. Don't get a repellent though, everything I've read about carpenter ants says that. And yeah, if they have a nest back there, it's because of a water problem.
Scully 06-07-2013 10:14 PM
what type of caulk should i use?
any idea when this type of siding was put in?
oh'mike 06-08-2013 06:51 AM
You need to pull off the siding in that area--repair the rot and then flash that lime stone cap in some way to keep water out of your house----
Also pull off the bottom course of siding at the patio slab----you may have serious rot/bugs from that wet installation.
Startingover 06-11-2013 06:48 AM
flying ants in bathtub
oops. posted in wrong place.
eharri3 07-31-2013 03:50 PM
7 dust works well, will kill pretty much anything that crawls. But with carpenter ants you really need to find the nest, which is probably in wood somewhere underneath that siding. And you need to make sure you treat THAT with a strong insecticide. If it can't be found once you pull the siding you'll need to find some other way to locate it and get the dust in there.
