Ants In The House - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 03-12-2014, 01:06 PM   #1
Rewards Points: 20
Ants in the house
I am finding one or two ants, every couple of days, in my finished basement. I think they are Carpenter ants. I don't know where they are coming from. I find them on the tiles walking in random directions, around the bathroom and laundry room.
I pick them up and flush them, generally.
Is this an indication of a problem in the house, or just a few stragglers getting in the house during the cold weather?
Thanks,
BCSapper is offline   Reply With Quote
Old 03-12-2014, 02:16 PM   #2
Rewards Points: 154
Generally speaking, occasionally finding ants in the house during the warmer weather is not evidence that there is a colony in the house. It doesn't mean that there isn't, but you could also be looking at stragglers that found there way inside from an outdoor nest while in search of food. Even if you see swarmers, the chance that they will actually find a mate and start a colony inside the home is small.
Ants in the house during the colder fall and Winter months can indicate you have a problem: Swarmers have gotten into the house and succeeded in starting a colony that has thrived in the warmth of the home throughout the Winter.
You have a few options: You can call an exterminator, try to track the ants to their nest and treat it directly, or you can get baits. Carpenter ants are known to be pickier than some of the other species out there when it comes to food, and some say trying to bait them will be hit or miss, but there have been some baits that claim to be able to attract them. My normal pest control routine involves multiple baits of various brand both inside and outside the house as soon as the weather starts to warm up, and before I actually start seeing ants on the ground. I also have an exterminator do a preventative spray on my peremiter and basement once a year in march. Then once that starts to lose effectiveness I put 7 dust or some other insecticide around my foundation about once per month in late summer and fall. The stuff has seemed to work well, as I regularly find dead insects that made it no further than the window sill.
If you wait until you see a bunch anything the problem will be harder to eliminate.
eharri3 is offline   Reply With Quote
Old 03-13-2014, 09:40 AM   #3
Rewards Points: 20
Thanks for the reply. I'll look into the baits when I'm in town this weekend. The snow is melting pretty quickly now so I should be able to see if they are on the outside too.
Old 03-13-2014, 10:38 AM   #4
Rewards Points: 12,794
Need to ID the type of ant you have.
Carpenter ants can be very destructive, seeing them in the basement would tell me there may be some issues with the way the walls here built when that basement was finished.
Moisture and rotting wood behind those walls is a common issue in basements.
Old 04-23-2014, 10:01 AM   #5
Rewards Points: 44
Get the gels and granuals from doyouownpestcontrol.com also buy some suspend SC and spray the entire house, especially cracks and crevices.
Its what I did, on my own home and i've not seen an ant since.
TheDoc46 is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Carpenter ant advice dcentuori Pest Control 53 11-26-2012 11:58 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
