Ant Infestation! - Pest Control - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-27-2007, 08:42 AM   #16
Ya I've read that too, although I figured why even bother with boiling water if I can just use borax/boric acid mixed in the water?
Yeah, seems like they've gotten good at avoiding my baits (the more I learn about ants, the more in awe I am of them. Smart lil creatures!). I guess I'm gonna have to find that colony!! (or should I assume colonies? Guess I'll find out after killing the first!)
joeyboy is offline   Reply With Quote
Old 07-27-2007, 09:13 AM   #17
Rewards Points: 180
What sprays are they using that I can't get at home depot?
Not many.
Some may just have different names
Combat is a good example
For years, and possibly still, the public could not buy Maxforce products because they were labeled for professional use only
The only difference between Maxforce and Combat is the label
Same company, same packaging
The trick is to find the active ingredient and then match that with a OTC product
Imidicloprid isthe favored AI for now
Bifenthrin is a restricted use pesticide, so few companies are using it these days
There are many better products for carpenter ants that do not pose the environmental hazard that Talstar does and do not require breaking the law to buy
I never found it to be the product it was claimed to be anyway
ocoee is offline   Reply With Quote
Old 07-27-2007, 09:25 AM   #18
Rewards Points: 180
Mounds are constructed so that the queens chamber will never flood
Boiling water will kill of some but not all of the ants and they will move the queen out to repopulate very quickly
Aerosols pyrethrins work great
Use a tip with a straw attachment and give three to four, more or less depending on the size of the nest, quick blasts with the straw inserted into the nest an inch or so
You should be able to see the vapors coming back out of the holes this will effectively fumigate the nest and kill all ants inside
Placing a bait in or on the nest will also not be very effective, you have to place the bait where they can find it through normal foraging activities
Baits can be tricky
If you injure a colony but do not kill it with these baits that colony and it's decendants will never take that bait or any bait using that base again
If the bait's active ingredient is too strong you will have the counter productive effect of forcing the colony to split
They send out a certain number of foragers if enough foragers,within the accepted range of loss, do not come back the colony senses danger and will move or bud/split
If the bait is so strong that it kills the foragers before they can get back to the nest the bait obviously will not work
before anyone mentions grits, they fall into that category
They queens and larvae are fed liquid not solid food so it will never get to them, but you will get that impressive body count that actually means very little
Old 07-27-2007, 10:51 AM   #19
Custom Cabinet Maker
Joey, so far you have wasted more time and effort and still have em than had you just called and problem would have already been taken care of
skymaster is offline   Reply With Quote
Old 07-27-2007, 12:45 PM   #20
If I was into calling a professional and paying them, instead of doing things myself, I wouldn't be posting in DIYchatroom in the first place
Old 07-27-2007, 12:49 PM   #21
I've wasted like, 10 minutes. I grabbed ant stakes at home depot while there for other things, and then put them around the house.
Anyways, I just got back from another home depot trip - I have a pound of powdered ortho-boric acid, and am going to look up how to use it.
Ocoee, so pouring the water / poisons in won't get the queen? Then there'd be no point! I wish people didn't post articles online saying to pour 3 gallons of boiling water into the mound, cuz that'll totally kill the queen!!
Ocoee, any advice you wanna give me that you don't think I'll find on my own regarding this powdered ortho-boric acid would be great!
Old 07-27-2007, 01:40 PM   #22
some updates
orthoboric acid IS just another name for boric acid
it can be mixed in with water
it seems to be very, very safe compared to any other products I've been using.
Well, I found where their nesting - I have a palm (type?) tree near the house, and it's got 3 main trunks that meet at the ground - in their intersection is where the ants are going... Gonna check around real quick to see if it's okay to use the boric acid there or if it'll kill my palm...
Old 07-27-2007, 08:21 PM   #23
Rewards Points: 180
Thank you
This is one of my pet peeves
Pros are not intellectually superior we just have superior knowledge through experience
That knowledge can be passed on easily once we get over ourselves just a little
All it take is patience and the realization that we did not always know it all
Yes I am a pro
Joey
Boric acid will not kill your tree and you can mix it with water
If you mix it with water make sure that it can be sprayed and that you continuously agitate the mixture to avoid clogs
Boric acid is one of the oldest, most versatile and safest pesticides on the market
It is used in emergency eye washes and laundry soap
Personally I would not have chosen this method, but I'm a pro and we don't think like that
Actually it is because it doesn't work fast enough and I don't like call backs that I don't get paid for, keep this in mind when using it
There is no reason that treating the base of the palm would not work, especially if you make sure that they do not have another avenue to escape
Treat your house with it also
Spray a perimeter band up to the level of the windows and around all windows and doors
if you use it as a bait
Use very little, you don't want it to work to quickly
I think the percentage in Terro is about 5% and I would cut that with another sweet liquid
Standard recipe was 1 part Terro to 2 parts syrup, honey or even water
OI would change up the flavors of syrup t prevent bait shyness
Boiling water looks impressive because of the massive body count
But also fire ants have mutated or evolved
When I was a kid you would see one tall fire ant mound for about a 1/4 acre or so
That is because the fire ants would hunt and kill anything in that zone including other fire ants
We did a very good job of killing these easy to find ants so nature and survival took over
You now see low almost flat mounds with several in close proximity
That is because they are cousins and no longer attack each other
The old single queen species evolved into the polygyn species that we have today
Thus
Kill the queen and they simply select another, and she may be among the group that is not in the mound at the time of the boiling water application
Old 07-27-2007, 08:23 PM   #24
Rewards Points: 180
Are these ant black with long legs and bent antennae ?
Old 07-28-2007, 11:25 AM   #25
Are you asking me about my ants? If so, the kid at the local home depot told me they sounded like sugar ants, although wiki seems to think those are australia only (i'm in FL).
Anyways, I think the problem *may* be under control. Every morning, there's the same line from my cat's bowl, to the office wall. I know they have their nests out there.
Last night was the attack.
Today, not a single ant at his bowl (even after heavy killing/arsenic baiting there's still a couple there).
What I did last night.
1) made 4 piles of their favorite food (my cat's dry food lol) and marked with shims.
2) waited hours until they found the piles and had their little lines going back and forth with the food.
3) used about 1/4 pound (roughly a fourth of my 99% pure boric acid bottle) of my powdered boric acid, I put it in a rinsed milk jug, filled completely with hot water, and shook til I had a blue liquid.
4) followed their little trails, easily found where they entered the ground, and dumped my solution into it. I think I found 6 spots, and I spread the gallon pretty evenly through all of them
And this morning I went out there and hosed the spots (since 3 of their homes were the bases of mature plants) down a ton to hopefully rinse the boric acid, as I didn't check ocoee's response before going out lol.
That stuff I used cost under $5, adn this morning when I was rinsing the spots I doused, I saw zero activity, so I think it worked pretty well.
Old 07-29-2007, 08:25 PM   #26
Rewards Points: 180
double post
Old 07-29-2007, 08:27 PM   #27
Rewards Points: 180
You could also use one of those hose end sprayers for powdered fertilizer like peters or miracle grow
The activity you describe sounds like either Crazy ant or related/Robust crazy ants
Both form super colonies and are active foragers
Keep a lookout for satellites
Oh, tell the kid at Home Depot not to quit his day job.
There is no such thing as sugar ants. There are sweet feeding nd grease feeding ants and that sometimes is only dependent on the life cycle of the nest at that time
Old 07-30-2007, 10:03 AM   #28
Ya that kid did seem a little clueless - that's why I come here for advice haha. But I still tend to ask questions while there, just to get more opinions.
Also I've read about that, at diff times of the year they have different macronutrient requirements, interesting stuff. I actually find ants really interesting, wish I wasn't at war with them lol.
I'm considering doing the boric acid powder around the whole edge of the problem areas (kitchen corner / office), I imagine this is just drilling holes in the lower parts of the wall and spraying powder (would I do this between every stud?). Their activity seemed nonexistant after the boric acid dousings, but now I've been seeing a couple here and there, so gonna have to do more...
Old 07-30-2007, 10:13 AM   #29
Rewards Points: 180
Mostly we just dusted behind switch plates, around windows and any cracks we find in the walls
When you apply the dust don't over do it
Most people want to apply these barriers lines around the perimeter
Dust should be applied as a thin film like household dust (at my house)
If you use it in a bait apply th bait where you don't mind the ants being if you apply it on the kitchen counters where everyone else does you will have to put up with them for awhile
We also used to mix up a peanut butter based bait or apple jelly and put it in the switch plates to keep them in the walls
Customers thought we were miracle workers because the ants saw no need to come out in the open if the food was in the walls with them
Old 08-10-2007, 01:18 PM   #30
Joeyboy- I tried sprinkling cayenne powder around the side of the house they were coming in and it stopped them. I guess ants don't like it hot!
WILDLILY is offline   Reply With Quote
