Ant Infestation! - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-24-2007, 01:41 PM   #1
Ant infestation!
Hundreds of ants have infested our house! I'm not sure where they're coming from but i think somehow they are managing to seep through the brickwork as they have started to appear throughout small holes in the walls at the top of our landing as well as under the lino flooring in our kitchen. What could i use to kill them?
joanne_m27 is offline   Reply With Quote
Old 07-24-2007, 05:20 PM   #2
Custom Cabinet Maker
Call Exterminator now. Explain "holes in the wall"????? Ya mean they have tunneled thru the drywall and come into the house this way? That is bad if true.
CALL
JackM
skymaster is offline   Reply With Quote
Old 07-25-2007, 10:37 AM   #3
Rewards Points: 180
Ants are easy to kill, you just have to destroy the nest
What kind of ants are they
Small or large?
What color?
What are there trailing habits?
Don't call the pros just yet they are usually over rated
ocoee is offline   Reply With Quote
Old 07-25-2007, 09:10 PM   #4
Remodeler
MinConst's Avatar
Depends on where you live. We moved to Florida last year and without a "Pro" we would still have ants. I did everything I could before calling in a professional. Since then we have had none. Might be different in other places but here you need a bug guy.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 07-26-2007, 08:30 AM   #5
Rewards Points: 180
I live near you
Old 07-26-2007, 05:46 PM   #6
uhh, damnit!
I live in central FL and was just about to start a thread on this.
We moved into this place ~ 2 or 3 months ago. Had a little bit of an ant issue. Put 'grants ant killer' stakes all over the place, outside and inside. I used 30 stakes so far (these are stakes that have food + arsenic, so the ants bring the arsenic trioxide back to their colony and it kills them all).
At first, it was working fine, until maybe 5 days ago.
We had no ants, the stakes were great, then one day there was a line of ants connecting my cat's food bowl to the office wall. They were just walking there and back, half one way, half the other.
Found the hole they were getting into the block house through and sealed with expanding great stuff foam. Put 3 grants stakes outside near the hole. Put 7 (7!) stakes in the office all around their path and their entry point at the wall. This worked for about a day or two, now they're back again.
Is there really nothing short of calling in exterminators? What sprays are they using that I can't get at home depot?
joeyboy is offline   Reply With Quote
Old 07-26-2007, 05:52 PM   #7
I've had good luck with Demon WP (Wettable Powder) for roaches, and it's listed for ants as well. Do a google for it... it's relatively inexpensive and pretty easy to apply.
steve771 is offline   Reply With Quote
Old 07-26-2007, 07:21 PM   #8
Rewards Points: 150
I've used baited Diatomaceous Earth quite sucessfully with ants...
slakker is offline   Reply With Quote
Old 07-26-2007, 09:34 PM   #9
Remodeler
MinConst's Avatar
Who knows what the heii they use. It works and its the best money spent. I personally don't like trying all these chemicals not knowing what I'm doing. Thee are kids, pets around that it might effect.
The bug guys need to me a living too so why not give them the job they know best. It really isn't that expensive when you consider all you go through trying to do what they do in a day. Since we have Joe we don't have ants. They did just what joeyboy described and it's called trails.
Web
One Man Shops
Old 07-26-2007, 09:47 PM   #10
Remove any food/water source and they will not have a reason to stay around.
redline is offline   Reply With Quote
Old 07-26-2007, 09:58 PM   #11
i don't think my cat would like me removing his water/food bowls very much....
BTW, is redline referring to cars, or the energy pills? Either way, right on!
Old 07-26-2007, 10:12 PM   #12
Found this on the web -not sure if it works.....
Get some Boraxo powdered soap and some corn syrup. Heat the corn syrup, do not let it boil, then mix in the boraxo! They will eat the stuff and take it back to the queen. It will kill them. Mix about 1/2cup syrup with 1/2 table spoons of Boraxo. Pour some of it, a dime size will do, on some paper and place it where they are at.
(redline=porsche 911 turbo)
Old 07-26-2007, 11:17 PM   #13
Rewards Points: 180
Rules of ant treatment
The only way to cure the problem is to kill the nest.
If you see dead ants, the bait ain't working
If they take the bait for a few days and you see a reduction in ants and then you see a resurgence, you just created bait shy ants
Baiting is generally the least effective way to treat ants, it's just usually the most convenient
Hot rainy season is ant in the house season
And rulele one identify the pest ant
Kill the queen and many species will simply elect a new queen
Kill too many foragers and the colony will sense danger and split or bud
Every time they bud they feel the need to bring the new colony up to full capacity before budding again
Different species of ant act and forage different ways, there is no catch all treatment that so many people want to
Many ants, Argentine, Crazy, Big Headed and Carpenter generally don't respond well to baits
Ghost ants may or may not
Fire ants and Pharoahs usually do
But the best method is still find and destroy the nest
Oh and the bugman probably will misidentify the ant also because he is too busy to check the chart or simply does not know how
Old 07-27-2007, 02:27 AM   #14
Rewards Points: 150
BIFEN I/T aka TALSTAR, you can get it on ebay. that's what some pros use. kills just about any bug that moves... seems to have worked for me, no more ants (carpentar)
Hain't we got all the fools on our side?
And ain't that a big enough majority in any town?
-Mark Twain
elementx440 is offline   Reply With Quote
Old 07-27-2007, 08:15 AM   #15
I have heard people pouring hot boiling water into the nest to kill them but I have not used this so do not know how effective it is.
