Removing and replacing insulation may be a good idea
That cost of removal is about $2 a foot
Another method is to treat the attic with a enzyme that attacks bacteria
This will help to break down any organic material and destroy the scent trails that are bringing new rats in
That costs bout .30 cents a foot
Then you can reinsulate with blown in
The holes are probably staring you in the face
I have gone to many many accounts where the home owner tells me that he has gone over it with a fine tooth comb and can find no entry points
One guy in particular was a home builder with over 30 years construction experience
Standing in his driveway before I even began my inspection I pointed out two active entry points
The two key areas that I find most opften are
AC chase ways
If your AC is the old outside unit where the piping goes up the side of the house and then into the attic, with a square metal cover over the pipes
Check to see if the bottom of that chase is open
If so that is an invitation and direct access to the huse
Second is eave gaps
Where two roof lines come together and for a sort of pocket
This is the best I could find right now
Look where the dormers are on this roof and where one roof line runs into the other
There will be a gap in that eave gap that will sometimes be large enough for rodents to come through
http://www.realestateroofing.com/images/roofparts3.jpg
I have never done this before, but if things I have shown you are not the problem
Take good digital pictures of your house
Perhaps I can see some problems
Like I said I have never done an inspection based on pictures, but it will be fun to see if I can
