Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Pest Control
Old 12-16-2012, 11:25 AM   #1
animal under house
Hi,
I have a house that sits on a concrete slab and there is no crawl space under the house. I have an animal living under the house and I can't figure out where it's getting in. I found out he was there when I could hear it itching itself with it's hind leg..I could hear his leg bumping into the wood. How can I get it out from under such a small space? Smoke bomb? Electronic device? I will be trying to find his entry hole while waiting for some replies...Thanks!
Mark Bogart is offline   Reply With Quote
Old 12-16-2012, 11:32 AM   #2
animal under house
Originally Posted by Mark Bogart View Post
Hi,
Find a company that will raise your house off the slab....remove animal...have company lower house.
Really??
hammerlane is offline   Reply With Quote
Old 12-16-2012, 12:31 PM   #3
animal under house
If it's a slab home then there is no wood under it.
Old 12-16-2012, 12:46 PM   #4
animal under house
The wood is above the slab,,framework, sub-floor. This sounds like a good size critter and I'm worried he will chew up through the floor and join us in the house,,maybe while we are sleeping.
I was actually hoping for some replies from professionals that would help me out here...my wife is really bugging me about this and I'm not sure how to solve the problem.
Old 12-16-2012, 12:59 PM   #5
animal under house
1. Find out where animal is entering,
2.When animal leaves to scavenge for food, a mate or to play, secure entering area.
really not much professional help needed....just a tin foil hat I guess
Old 12-17-2012, 07:29 PM   #6
animal under house
One trick to finding the entry is to sprinkle some flour around the suspected possible entry points. You will see footprints. If your floor sits on a slab and you hear an animal below, there has to be an entry.
Do you have a deck or porch that could hide the entry? If not, and the siding is tight against the foundation, then the animal may be entering from above. The garage is another possibility. Garages are very easy for small rodents to freely enter, and if it is connected to the house, it could have hidden little entries into the main structure.
Do you hear the critter only at certain times? When? Everyday? Does it stop or move when you whack the floor near the sound? What is near the sound inside your living space? (plumbing, electric, heating vent....)
good luck
gary
gobug is offline   Reply With Quote
Old 12-17-2012, 07:34 PM   #7
animal under house
If you do find tracks, that is a good clue about what animal it is. That would influence the size of a trap, and the bait used to capture it.
Depending on your neighborhood rules, local laws, even federal laws, you may have only certain choices. For example, in Fort Collins CO I cannot relocate a skunk, nor exterminate it on the spot. Woodpeckers are protected by federal law and international treaty. It is important to know what critter is cohabitating with you.
Forget the bombs or electronic devices. CO does not allow sales of the electronic things in local stores, because they test them and none work as advertised.
Old 12-18-2012, 03:50 AM   #8
paper hanger and painter
chrisn's Avatar
animal under house
Hi,
you sure about that?
probably this guy or girl
Old 12-18-2012, 07:12 AM   #9
animal under house
Originally Posted by gobug View Post
One trick to finding the entry is to sprinkle some flour around the suspected possible entry points. You will see footprints.g
Now theres a good tip.
Old 12-18-2012, 08:24 AM   #10
JOATMON
ddawg16's Avatar
animal under house
Your other concern.....if it's a female, there could be babies in there.
Depending on where you live (this is why having your location in your profile helps)....flower may or may not work..rain will turn it into mush....but it's still a good idea....
Traping is one option....HF sells safe traps (animal is not harmed). Works best if you can find the entry point....then put the trap in front of it.
You also need to know what kind of creature it is....if the weather goes along...the flour trick might help.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 12-18-2012, 06:05 PM   #11
chrisn's Avatar
animal under house
This guy can tell the difference from a ground hog, raccoon, skunk, cat, rat, etc, from a track in the flour?
Old 12-18-2012, 08:06 PM   #12
animal under house
I have a handbook of animals in CO. It tells about each, show pictures, and shows footprints.
The Following User Says Thank You to gobug For This Useful Post:
DangerMouse (12-18-2012)
Old 12-19-2012, 04:19 AM   #13
chrisn's Avatar
animal under house
I would bet MOST people do not.
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
