-   Pest Control (http://www.diychatroom.com/f51/)
-   -   animal under house (http://www.diychatroom.com/f51/animal-under-house-166602/)
Mark Bogart 12-16-2012 10:25 AM
animal under house
Hi,
I have a house that sits on a concrete slab and there is no crawl space under the house. I have an animal living under the house and I can't figure out where it's getting in. I found out he was there when I could hear it itching itself with it's hind leg..I could hear his leg bumping into the wood. How can I get it out from under such a small space? Smoke bomb? Electronic device? I will be trying to find his entry hole while waiting for some replies...Thanks!
hammerlane 12-16-2012 10:32 AM
Originally Posted by Mark Bogart (Post 1074028)
Hi,
Find a company that will raise your house off the slab....remove animal...have company lower house.
Really??
joecaption 12-16-2012 11:31 AM
If it's a slab home then there is no wood under it.
Mark Bogart 12-16-2012 11:46 AM
The wood is above the slab,,framework, sub-floor. This sounds like a good size critter and I'm worried he will chew up through the floor and join us in the house,,maybe while we are sleeping.
I was actually hoping for some replies from professionals that would help me out here...my wife is really bugging me about this and I'm not sure how to solve the problem.
hammerlane 12-16-2012 11:59 AM
1. Find out where animal is entering,
2.When animal leaves to scavenge for food, a mate or to play, secure entering area.
really not much professional help needed....just a tin foil hat I guess
gobug 12-17-2012 06:29 PM
One trick to finding the entry is to sprinkle some flour around the suspected possible entry points. You will see footprints. If your floor sits on a slab and you hear an animal below, there has to be an entry.
Do you have a deck or porch that could hide the entry? If not, and the siding is tight against the foundation, then the animal may be entering from above. The garage is another possibility. Garages are very easy for small rodents to freely enter, and if it is connected to the house, it could have hidden little entries into the main structure.
Do you hear the critter only at certain times? When? Everyday? Does it stop or move when you whack the floor near the sound? What is near the sound inside your living space? (plumbing, electric, heating vent....)
good luck
gary
gobug 12-17-2012 06:34 PM
If you do find tracks, that is a good clue about what animal it is. That would influence the size of a trap, and the bait used to capture it.
Depending on your neighborhood rules, local laws, even federal laws, you may have only certain choices. For example, in Fort Collins CO I cannot relocate a skunk, nor exterminate it on the spot. Woodpeckers are protected by federal law and international treaty. It is important to know what critter is cohabitating with you.
Forget the bombs or electronic devices. CO does not allow sales of the electronic things in local stores, because they test them and none work as advertised.
chrisn 12-18-2012 02:50 AM
1 Attachment(s)
Hi,
you sure about that?:laughing:
probably this guy or girl
hammerlane 12-18-2012 06:12 AM
Originally Posted by gobug (Post 1074841)
One trick to finding the entry is to sprinkle some flour around the suspected possible entry points. You will see footprints.g
Now theres a good tip.
ddawg16 12-18-2012 07:24 AM
Your other concern.....if it's a female, there could be babies in there.
Depending on where you live (this is why having your location in your profile helps)....flower may or may not work..rain will turn it into mush....but it's still a good idea....
Traping is one option....HF sells safe traps (animal is not harmed). Works best if you can find the entry point....then put the trap in front of it.
You also need to know what kind of creature it is....if the weather goes along...the flour trick might help.
chrisn 12-18-2012 05:05 PM
This guy can tell the difference from a ground hog, raccoon, skunk, cat, rat, etc, from a track in the flour?:huh:
gobug 12-18-2012 07:06 PM
I have a handbook of animals in CO. It tells about each, show pictures, and shows footprints.
chrisn 12-19-2012 03:19 AM
I would bet MOST people do not.:laughing:
