Advice For Flea Infestation In Empty Rental House. - Pest Control - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Pest Control
Old 07-12-2015, 10:04 PM   #1
Rewards Points: 132
Advice for flea infestation in empty rental house.
Rental house with hardwood floors throughout, and no furniture. Walking in for about 5 minutes i will get 10-15 on my legs. Left a water/dish soap trap overnight with a light on it, and got about 50.
I did some reading on homemade remedies and spread a large amount of borax throughout the entire house/cabinets. I'm not sure how effective that will be, though, and i think it mainly only affects the larvae and not the existing fleas.
Considering flea foggers, or chemical sprays i can find online. Are either of these options very effective, is one better than the other... or would it be best to not bother with either and call an exterminator?
The chemical sprays i have briefly researched are Permethrin SFR 36.8% or Cyonara 9.7.
Searching this forum i saw Precor 2000 and Ultracide mentioned, but i havent researched them yet.
Thanks!
tireshark is offline   Reply With Quote
Old 07-12-2015, 10:49 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 4,226
You really need to call in the professionals. Once they get into the walls and cracks between the baseboards and flooring. It is hard to get them out.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
The Following User Says Thank You to gregzoll For This Useful Post:
tireshark (07-13-2015)
Old 07-13-2015, 08:50 AM   #3
Rewards Points: 1,372
Yrs ago I was told to put a couple of moth balls in the vacuum bag so that any you vacuum up will die.
Startingover is offline   Reply With Quote
The Following User Says Thank You to Startingover For This Useful Post:
Old 07-13-2015, 09:58 AM   #4
Rewards Points: 436
I myself would go with a couple of bombs and then look at other options
BrowneBearLLC is offline   Reply With Quote
The Following 2 Users Say Thank You to BrowneBearLLC For This Useful Post:
craig11152 (07-13-2015), tireshark (07-13-2015)
Old 07-13-2015, 11:04 AM   #5
craig11152's Avatar
Rewards Points: 624
I agree. While you can't go wrong with a pro, they are going to do essentially the same thing. Bomb it once, bomb it twice, then call a pro if they are still alive.
Finally, he switched to a bone saw to finish the job, and at 9:17 p.m., Mountain time, the head of the greatest hitter who ever lived had been sliced off.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
Old 07-13-2015, 02:32 PM   #6
Rewards Points: 132
Thanks guys. I spent a lot of time reading reviews and methods last night, and i decided to order this stuff:
Precor 2000 Plus
It has fantastic reviews, and i read 3 or 4 reviews that said when they had previously called the exterminators for fleas, they showed up using only this product. It's supposed to kill both the adults and the eggs.
Precor 2000 Plus
Old 07-13-2015, 06:08 PM   #7
Rewards Points: 40
Had a nasty flea infestation a couple years ago -- called in the pros. Took 3 or 4 treatments soaking all floor surfaces, wood, carpet, everything, with progressively diluted Onslaught. Worked very well and I haven't seen a bug of any variety inside the house since.
http://www.domyownpestcontrol.com/on...ide-p-376.html
indigo is offline   Reply With Quote
The Following User Says Thank You to indigo For This Useful Post:
Old 07-13-2015, 10:31 PM   #8
Rewards Points: 214
precor 2000 + worked well for me. Alpine flea worked better.
Steam clean your carpets, use alpine flea as labeled, problem gone.
Pest Control Bellingham, WA
Gustavas is offline   Reply With Quote
The Following User Says Thank You to Gustavas For This Useful Post:
Advice - Whole House Fans ! sandy2982 HVAC 2 04-23-2008 12:53 AM
Old house new problems: I need advice SandyD Building & Construction 3 09-14-2007 10:53 PM
Buying house... Need advice! sweetsue777 General DIY Discussions 9 01-02-2007 04:11 AM
Need advice and assurance on house issues! Leikela General DIY Discussions 3 12-04-2006 10:10 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
