Window Mould/dirt - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 08-13-2011, 01:54 PM   #1
Window mould/dirt
Hi,
On my windows, there are mould like dirt growing (black colour/brown colour). They are trapped in between the thin gap. I am wondering if there are any products I can use to remove these?
Thank you very much.
diynoob2011 is offline   Reply With Quote
Old 08-13-2011, 04:14 PM   #2
DIY staff
Rewards Points: 7,174
Is the dirt between the panes of glass? Post a picture if you can---Mike--
Usually a good scrubbing with hot soapy water with a little bleach will get off surface grime and mold.
diynoob2011 (08-14-2011)
Old 08-13-2011, 04:34 PM   #3
m1951mm's Avatar
Like Mike said a picture would help narrow down the problem. It sounds to me like the caulking around your window is failing, leaving room for moisture to get inbetween the window and the wall. Your could try vinegar first to see if that cleans up the mould (more ecco friendly) but if that does not work bleach watered down will kill the mould. Rinse with clean water. Once it is dry you may want to recaulk. If it were me, I would carefully remove the old caulk, bleach it (watered down of course), rinse, let dry and then totally recaulk.
The pic would help in telling if that is what is really happening for you.
The same solution for this problem will take care of issues anywhere you have a caulk joint, be it in a shower, a floor, wherever caulk is used.
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
Old 09-03-2011, 09:36 AM   #4
Bleach - that's all you need! Cheap and effective, just try.
BrendaSimons is offline   Reply With Quote
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
