Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 09-10-2008, 08:33 AM   #1
Window blind installation
Hi everybody, I just bought a window blind and I need to install it. The set comes with screws to mount the supports on the wall (drywall). I can screw them in without drilling but after I make it through the drywall I hit a cement wall. Can I just drill in the hard wall and then use the same screws? Thanks, A
agimcomas is offline   Reply With Quote
Old 09-10-2008, 09:13 PM   #2
Nia
If you move the holes over to the left or right (maybe a inch or two) are you still hitting the cement?
Nia is offline   Reply With Quote
Old 09-12-2008, 05:01 PM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
I'd get some masonry screws. Not sure what kind of blind, but I wouldn't take a chance pulling the cord to open them and getting the whole bag o chips with the deal.
Don't ask about the naked flashing incident...
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 09-25-2008, 05:16 AM   #4
Yes, i would also suggest that you get masonry screws for that.
Last edited by AtlanticWBConst.; 09-25-2008 at 06:48 AM. Reason: SITE RULES VIOLATION: Advertising Links Removed From Signature
home decorations is offline   Reply With Quote
Old 09-27-2008, 10:14 PM   #5
Depending upon the weight of the blind, you can purchase a threaded plastic insert into the drywall(Toggler, is the brand name) that will accept a drywall screw. Toggler brand also makes a heavy duty "molly bolt" type of hardware insert that can hold up to 150 lbs. These require a 1/2 hole drilled through the drywall to install the hardware. Then you bolt(available in 3/16" or 1/4") to the fixture/blind to the wall. You will need to measure the depth of the sheetrock - masonry wall before you purchase the proper bolt length. I would guess that a 1 or 1 1/4" bolt would be plenty if the blind mounting hardware is less than 1/8th inch thick. This hardware is available in the big box stores or Ace hardware.
RemodelMan is offline   Reply With Quote
Retrofit Window Installation typerr Remodeling 4 10-28-2009 12:47 PM
Window Installation Guide Pondo13 Building & Construction 1 07-18-2008 06:49 AM
Window installation cost only. Changeling Building & Construction 18 06-30-2008 03:01 PM
Window Well Installation Bill46 General Discussion 1 04-03-2007 05:49 PM
