-   Interior Decorating (http://www.diychatroom.com/f50/)
-   -   Window blind installation (http://www.diychatroom.com/f50/window-blind-installation-26587/)
agimcomas 09-10-2008 07:33 AM
Hi everybody, I just bought a window blind and I need to install it. The set comes with screws to mount the supports on the wall (drywall). I can screw them in without drilling but after I make it through the drywall I hit a cement wall. Can I just drill in the hard wall and then use the same screws? Thanks, A
Nia 09-10-2008 08:13 PM
If you move the holes over to the left or right (maybe a inch or two) are you still hitting the cement?
DIYtestdummy 09-12-2008 04:01 PM
I'd get some masonry screws. Not sure what kind of blind, but I wouldn't take a chance pulling the cord to open them and getting the whole bag o chips with the deal.
Don't ask about the naked flashing incident... :whistling2:
home decorations 09-25-2008 04:16 AM
Yes, i would also suggest that you get masonry screws for that.
RemodelMan 09-27-2008 09:14 PM
Toggler
Depending upon the weight of the blind, you can purchase a threaded plastic insert into the drywall(Toggler, is the brand name) that will accept a drywall screw. Toggler brand also makes a heavy duty "molly bolt" type of hardware insert that can hold up to 150 lbs. These require a 1/2 hole drilled through the drywall to install the hardware. Then you bolt(available in 3/16" or 1/4") to the fixture/blind to the wall. You will need to measure the depth of the sheetrock - masonry wall before you purchase the proper bolt length. I would guess that a 1 or 1 1/4" bolt would be plenty if the blind mounting hardware is less than 1/8th inch thick. This hardware is available in the big box stores or Ace hardware.
