Width Of One Horizontal Stripe - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-26-2009, 07:15 PM   #1
Width of one horizontal stripe
How wide should one horizontal stripe be on a wall that is 8 ft in height? Does the stripe look better in the center of the wall or closer to the ceiling?
Debdeb is offline   Reply With Quote
Old 06-27-2009, 06:21 PM   #2
Rewards Points: 352
Get a couple of rolls of colored tape and play around with it before you paint it.
RegeSullivan is online now   Reply With Quote
Old 06-27-2009, 07:26 PM   #3
You asked how wide the strip. Then asked where it should be placed. Two different questions. For the location of the strip try the golden number. Divide the height of the wall by 1.618. Measure from the top or bottom of the wall and place a strip of masking tape along that line. It doesn't have to be an exact decimal measurement--- a fraction up or down won't look bad. Stand back and look. Then decide if it looks better closer to the top or the bottom of the room. Then decide on the width and color.
PLAIN O TX is offline   Reply With Quote
Old 06-27-2009, 09:56 PM   #4
Rewards Points: 672
Here's a cool kids room with a stripe in the middle of the wall.
If the link doesn't work, it's in the Project Showcase forum "New House DIY" by Comp1911. It's on page 7 of that thread.
New House DIY
gma2rjc is offline   Reply With Quote
Does return duct width matter? bvbellomo HVAC 13 01-11-2009 02:03 PM
Horizontal ground loop questions with geothermal smcmurrey HVAC 1 05-14-2008 10:06 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 06:47 PM
Suggestions to long horizontal run problem... slakker Plumbing 8 08-03-2007 12:45 AM
piece of horizontal wood through studs? yummy mummy Remodeling 13 11-24-2006 07:33 AM
