Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Interior Decorating
Old 10-20-2009, 09:02 PM   #1
Default White Vinyl Windows with wood trim-hate it
Just purchased and installed 8 white vinyl windows with white interior against my better judgement because we have all wood trim and just as I thought, I hate it. Any suggestions on toning down the glare of the white vinyl?
melindajanczur is offline   Reply With Quote
Old 10-20-2009, 11:15 PM   #2
Hide em with window treatments? You will not get regular paint to stick to them. Rustoleum does make a plastic primer in liquid form you could try on a small section to see if it held. Krylon Fusion is for plastics and vinyl but as far as I know it only comes in spray cans so you would have to mask everything off well. Melamine paint might be a possibility but I have only heard of it being used for kitchens and baths in the home. I am not sure how any of these possibility will hold up to constant heat and light from the sun coming through the windows.
sdsester is offline   Reply With Quote
Old 10-21-2009, 12:23 PM   #3
Newbie Bill
Change the trim to white?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 10-21-2009, 01:56 PM   #4
yeah I would just put some nice window treatments over them and you won't really notice them as much
good luck
drillbitter is offline   Reply With Quote
Old 10-25-2009, 09:57 AM   #5
Thanks, I think I'm going to go with the window treatments for now, less complicated and maybe they will grow on me
Old 10-26-2009, 11:33 PM   #6
Default Let the Eye Focus on Something Else
A trick I learned about interior decorating is to let the eye focus on something else. In other words, rather than trying to re-do the vinyl windows, put something on the walls that will draw the eye away from the windows. Inexpensive but very exciting things to use are wall decals. I get mine from http://www.wallslicks.com. You might want to check out their site for a lot of design options, colors, sizes, etc. These decals have a matte finish so they blend right into the wall and look like the design was painted on by a professional. You'll get a very classy look to your room, and no one (not even you!) will be looking at the windows.
lvdecor is offline   Reply With Quote
More On This Topic
Maybe your vinyl fence is looking a little worn. Or, perhaps you want to change the color of it. Painting a vinyl fence is possible but you need to buy the correct kind of primer and paint. Not just any paint will adhere to the vinyl surface. Follow... Read More »
In this clip I'm going to show you the best way to remove vehicle graphics. Okay, now that they've put graphics on, the customer decides they didn't like it. There are several things you need to take it off. One, is the little squeegee with a sharp edge... Read More »
Now we're ready to apply the pressure on the bubble. Secure it. Get it anchored back down to the substrate again. The way we do that is with the clamps and blocks. We've got several different kind of blocks we can use. We've got MDF, you can use part... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
In this clip we are going to show you how to pressure wash a window. I already have a deflector shield. I noticed it might have an area where water might seep under the window on this particular window so I have an old piece of plastic that I like to... Read More »
cream trim downstairs, white trim upstairs, advice for stairs? allyr Painting 1 09-26-2009 06:01 PM
Frost on interior of vinyl windows d.sharkey Building & Construction 8 07-06-2009 08:25 PM
Replacing mylar windows with vinyl windows turkeybday Building & Construction 1 03-02-2009 08:03 AM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 07:48 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 10:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
