White Plastics Going Off White In Our House - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 03-19-2010, 06:02 PM   #1
white Plastics going off white in our house
I am having problems with some of the whit plastics in our house going off white. most of our alarm sensors, smoe light swithces and just one airconditioner duct (pictured).
What causes this and can it be fixed? if not how do you stop or minimise it?
agdp07 is offline   Reply With Quote
Old 03-19-2010, 06:58 PM   #2
Learning by Doing
Leah Frances's Avatar
Bump to follow thread.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-23-2010, 03:36 PM   #3
Strange, normally I would expect that from sun damage. Is the yellowing duct over the stove area? Wonder if you're getting airborne oils on it (unintentionally of course!).
You might try attacking the stains with a Magic Eraser or even soaking them in a bleach-bath. But I'd probably guess it's permanent. Suppose you could also cover it with that new fancy plastic paint I've seen at the hardware store.
Good luck!
aimeesrockworks is offline   Reply With Quote
Old 03-26-2010, 08:41 PM   #4
Its in our living room which has nothing but books and 2 lounges.
Its weird because the outer rim isnt effected.
I have hads alot of white plactics over the years do this in different houses.
Didnt realise it would be this hard to get an answer to be honest as Im sure Im not the only one who has this problem.
Old 03-29-2010, 11:39 AM   #5
I remember reading an article on a computer forum about people who restore old PCs. The white plastic cases tended to yellow because of a flame retardant that was added to the plastic. I don't believe contemporary white plastics have the same problem.
Here's just one hit I found:
http://hackaday.com/2009/03/02/resto...uter-plastics/
Do a Google search for 'restore yellowed plastic" and you'll get a bunch more.
The article has a formula for something to restore the white.
houseinthewoods is offline   Reply With Quote
Old 03-29-2010, 07:20 PM   #6
Wood Butcher
eagle09tbl's Avatar
I have had the exact same issue with the trim rings surrounding my recessed (pot) lights. So far I don't know what causes it or found anything to restore the bright white color.
I've had my house 9 years now and so far I've replaced the trim rings twice. Personally, I think it's just poor quality materials but I'll follow this thread with hopes that somebody offers a solution here. Thanks for bringing this up agdp07.
eagle09tbl is offline   Reply With Quote
Old 04-25-2011, 03:45 PM   #7
metal switch plates
I had this same problem in our previous home. With time all the white plastic switch plate turned an ugly ivory color from sun exposure. I didn't know what to do until a friend of mine recommended removing them and purchasing all metal switch plates. At first I thought she was crazy, but it turned out that the metal ones only cost me a few cents more than my plastic ones and I was able to get them in white metal. Perhaps you can switch to metal too?
mrominger is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 05:58 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
