Where To Get This Lighting Fixture? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 11-06-2014, 07:22 PM   #1
Rewards Points: 578
Where to get this lighting fixture?
My ceiling-mounted light fixture above the bathtub seems beat up. See photo.
I want to get the same kind of fixture (with the ring around it) to replace it. Where can I get it?
HomeLearner is offline   Reply With Quote
Old 11-06-2014, 07:44 PM   #2
DIY staff
Rewards Points: 7,174
I think that is a standard 6" can light and optional covered trim ring--
If so--you just need to go to the home Depot and look at the trim rings in the recessed lighting section---(LED trim rings are available for less than $25--)
Can you pull down the trim ring and see if I am right?
Old 11-06-2014, 08:09 PM   #3
Rewards Points: 578
I'll need to get a ladder before I can take down the trim ring. Will keep you posted on that.
Old 11-07-2014, 02:49 AM   #4
Rewards Points: 578
I don't see any screws on the side of the light fixture or the ring. How can I take the trim ring off?
Old 11-07-2014, 05:45 AM   #5
DIY staff
It is held up with two springy things---get your fingernails onto the ring and gently pull down---it should come down about 1 1/2"---to remove it--squeeze the wire springy things together---
Be careful not to drop the glass cover into the tub---a throw rug or towels in the tub are a good idea in case it falls.
Old 11-07-2014, 03:51 PM   #6
Oso954's Avatar
Rewards Points: 1,126
It looks like a Halo 172PS.
Assuming it is, you will not find it everywhere. It tends to be a special order item at the big boxes.
Oso954 is offline   Reply With Quote
Old 11-07-2014, 04:03 PM   #7
Rewards Points: 578
What do you mean by "big boxes"? Can you give some examples?
Old 11-07-2014, 04:47 PM   #8
Oso954's Avatar
Home Depot, Lowes, etc.
Old 11-08-2014, 05:39 AM   #9
DIY staff
While that exact cover might not be easy to find---there are many stock 'trim rings' what will work---there are mew ones that have LED lights built into the trim ring---
I like them--the LED lights look good and are supposed to last for many years.
Old 11-08-2014, 01:38 PM   #10
Oso954's Avatar
Without additional information, I would recommend sticking with a shower rated trim, whether it is LED or incandescent.
Not all LED trims or modules are shower rated.
The Following User Says Thank You to Oso954 For This Useful Post:
Thurman (11-08-2014)
Old 11-08-2014, 05:30 PM   #11
Rewards Points: 13,750
It should have been a shower rated trim ring, it will have a seal around the rim.
The diffusor looks discolored, may be because of to high a wattage bulb.
Old 11-16-2014, 09:39 PM   #12
Rewards Points: 578
An electrician took it down. It's Progress Lighting, model # P8007-60. I've ordered from Home Depot. Only available via online order.
Old 11-16-2014, 09:42 PM   #13
Rewards Points: 578
An electrician pulled down the ring and the fixture. He had to separate the ring from the fixture in order to get the manufacturer and model # on the inside of the fixture. It's a 6" Progress Lighting P8007-60 ceiling light.
The light bulb inside, believe it or not, is a 100 watts standard (traditional) soft white light bulb.
Old 11-16-2014, 09:46 PM   #14
Rewards Points: 578
It's a Progress Lighting P8007-60 ceiling shower light. It has a 100 watts traditional soft white light bulb inside, which may have caused the discoloration.
When replacing the old fixture, I'll probably use a 60 watts soft white light bulb to avoid discoloration.
Would an energy-efficient bulb equivalent to 60 watts be better for the fixture?
Old 11-16-2014, 09:50 PM   #15
Rewards Points: 578
Do you mean trim ring by "trim"?
An electrician took out the fixture and the ring, and got the information. A 100 watts old-fashioned soft white light bulb is inside.
The fixture comes with the trim ring. It's at http://www.homedepot.com/p/Progress-...Q&gclsrc=aw.ds
Old house w/ no ground, and new lighting fixture with no ground AfinShou Electrical 12 09-07-2014 04:23 PM
Existing Fixture with new Bathroom Fan? rootxploit HVAC 3 10-12-2011 12:08 PM
Lighting fixture safety standards BlueBSH Electrical 7 12-29-2009 10:03 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
